Why do aero bikes handle like barges or is it just me? [emoji2369]
ultyguy
by ultyguy
So I’ve had a few aero bikes over the years as they are obviously faster, especially at race speeds (when I’m trying to close back the gaps after getting drop in climbs by skinny guys). However, I haven’t found a single one that does have a fair amount of understeer to it. I have no clue if this is a user issue or something else. The geo of all these bike have been a carbon copy of ‘normal’ race frames so it’s not in the geo.
Aero bikes ridden
Canyon Aeroad
Scott Foil
Felt AR
Anyone had similar experiences? Am I just crazy. Do you have an aero bike that doesn’t feel like this?
jlok
by jlok
Propel Adv SL Disc. Quick and responsive handling.
Rikulau V9 DB Custom / BMC TM02 < Litespeed T1sl Disc < Giant Propel Advanced SL Disc 1 < Propel Adv < TCR Adv SL Disc < KTM Revelator Sky < CAAD 12 Disc < Domane S Disc < Alize < CAAD 10
ryanw
by ryanw
Throw your leg over a new Venge and thank me later.
'16 Cervelo S5 - 6.65kg RIP
'17 Focus Mares Force 1 - 7.8kg
'19 Cervelo S5 Disc - 7.25kg
‘20 Allez Sprint Disc - 7.67kg
IG: RhinosWorkshop
Campervan
by Campervan
ryanw wrote:
Thu Apr 18, 2019 2:42 pm
I was about to same virtually the same. I did find the BMC TMR01 more relaxed than the new Venge.
BMC Granfondo 02 105
Btwin 540
Specialized Venge Pro Disc
jfranci3
by jfranci3
When do you notice this? Are you on stock wheelsets/tires at your normal pressures? True understeer would come from weight distribution front/rear. I doubt you're losing traction with your front tire, so it's probably some other sensation. If it is true understeer, you'd likely want to shift weight rearward.
Youre probably saying high load cornering, your inputs feel less direct. Aero bikes have a narrower down tube, which might give this sensation. Other factors could be disc wheelsets have narrorer spoke falanges, aero forks/frames are less laterally stiff in general, some aero bikes have around 1cm longer wheelbase. If the bike is running different or fatter size tires it'll feel like understeer also. Even the same size Schwalbe Pro One feels radically different than a Hutchinson Galtikcon 11STORM! when you pitch the bike, with the Hutchinson feeling more oval and inexact.
rides4beer
by rides4beer
I've only ridden one, my Transonic, but it handles great imo (again, with nothing to compare it to). I guess I'd have to ride some others to know, but I've never felt unsafe riding in a tight group, or taking curves at high speeds. I haven't raced a crit with it, or anything like that, which I guess would be a better test of handling than a fast group ride.
refthimos
by refthimos
I find my SystemSix Hi-Mod to be quite nimble - it has a slightly different "feel" to it from my SuperSix, but I think that's mostly the result of the SuperSix being over 2kg lighter.
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8/FFWD Falcon | Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
dcorn
by dcorn
Understeer?? If your front tire is pushing through turns, you might be going too fast.
Haven't noticed any sluggish handling in my Aeroad compared to an S-works SL4 Tarmac or my new Allez Sprint. Maybe acceleration or snappiness, just because the Aeroad weighs a bit more and has much deeper wheels.
ChiZ01
by ChiZ01
check the HT angle and fork trail
