What handlebar to buy next
Attermann
by Attermann
Hello weenies
I had my TLO bar cracked by a extralite hyperstem, now I’m on the hunt for a new handlebar, I have looked at a darimo, but the prize is just tough to swallow
What reasonable light handlebar is there, that is short and shallow, external cabling, and not 400 euros. I hope you can help
Best regards
wheelsONfire
by wheelsONfire
Not easy to go much under 400 Euro. But i would go for Haero Carbon H145RR SL.
My 44 size weights 153g.
(375 Euro and has been since release date).
If you read on the tech behind them you might be swayed. The also got a a bit more heavy version at 175g size 44.
Anyway, drop 132mm / reach 70mm (both versions).
What you should know of Haero sizing. Size 44 is 41.6cm over hoods. Size 42 is 39.6cm and size 40 is 37.6mm over hoods
Funny you say that, i have used Extralite Hyperstem with mine. However i needed a longer stem so i just mounted Eastons EC90SL (quite a bump up in weight though).
From 82g to 138g!
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
ChiZ01
by ChiZ01
get an alloy bar and never have to worry about getting crushed by stem or bike falling over, carbon bar is just not worth it
1swiftvelo
by 1swiftvelo
Deda Traditional bend deep drop long reach. Aluminum. Love these.
spartacus
by spartacus
Are there any alumunum aero bars that are actually aero not just oval at the top?
Attermann
by Attermann
1swiftvelo wrote:
Sat Apr 13, 2019 11:16 pm
Long reach and deep drop are not for me, I like my handlebar short and shallow
Wookski
by Wookski
Attermann wrote:
Sat Apr 13, 2019 1:25 pm
Hello weenies
Best regards
Schmolke SL, choose the shape that suits you best.
Ditch the hyperstem as well, they’re rubbish.
robertbb
by robertbb
ChiZ01 wrote:
Sat Apr 13, 2019 9:38 pm
+1
alcatraz
by alcatraz
Or get an integrated bar and stem and never have problems wirh crushed clamp areas again, while maintaining a low weight (if chosen carefully, aero available).
tarmackev
by tarmackev
3T Toronova with 65% off. A real bargain! Tempted myself. https://www.chainreactioncycles.com/mob ... nt=product
kervelo
by kervelo
I just purchased a 3T Ernova Team Stealth from Wiggle (the same bar referred in the previous post). I was positively surprised by the flat top of the bar, although it is not very visible from the shop images.
Attermann
by Attermann
I had one of the older versions of the bar, so I like the flare and flat top, I can live with the internal cabling, because that’s really cheap, now I just need to figure out what to do with the stem. Thank you for the suggestions everyone
dj97223
by dj97223
Check out William CCS. <200g, sturdy and very reasonably priced. Allows for internal cabling but I run them outside because the cable bend is too tight for Campag 11 mechanical with the way I like the shifters.
icantaffordcycling
by icantaffordcycling
spartacus wrote:Are there any alumunum aero bars that are actually aero not just oval at the top?
Trek/bontrager make one that is currently on sale.
Specialized Allez Sprint
Instagram || Shitposting is a god-given right.
bikeboy1tr
by bikeboy1tr
kervelo wrote:
Sun Apr 14, 2019 5:28 pm
Thanks kervelo I just searched this bar and its onsale at CRC for $110 Can. wow what a smokin deal. Its lighter than my FSA K Wing and its getting old anyway.
Oh and tarmackev but your post lists the bar as Toronova which kind of threw me off. Should have just clicked the link.
"Life is like riding a bicycle. To keep your balance you must keep moving"-Albert Einstein
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
