3T Aeronova + Di2 cable length?
Konsi
by Konsi
Hello,
I am trying to figure out which length of cables I need to order to connect Shimano STIs (ST-R785) to a central junction box A (SM-EW90), mounted either under the stem or a Garmin mount in front of it, if I go for a 3T Aeronova (width 40cm) as handlebars. As I pay shipping on every order, I try to have fewer, larger orders and don't want to order the bars first to measure and then the cables. Will the 350mm-cables be long enough?
Best regards
Konstantin
ryanw
by ryanw
I think I used 300 or 350mm.
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
marek
by marek
I've used 350mm.
I wish You a lot of patience during installation of cables. I've done it twice and each time it took 3-6 hours. But second one was with Di2 hub installed at the bar end (even more difficult).
ryanw
by ryanw
Just buy a cable routing install tool like: https://jagwire.com/products/tools/inte ... uting-tool
Takes about 5 minutes.
IG: RhinosWorkshop
