Scott Bikes Rim Brake Future
CAAD8FRED
by CAAD8FRED
I emailed Scott about the future of rim brakes on their bikes and this is the response I got:
ChiZ01
by ChiZ01
after using mechanical disk for 2 month, there is really no comparison, better modulation, more stopping power, easier to clean, it is the future. also have other advantages of more tire clearance, ease to swap between 700c and 650c wheels. the only downside is the 2 lb extra weight
robeambro
by robeambro
CAAD8FRED wrote:
Mon Apr 08, 2019 7:25 pm
I'm not sure how their answer can be seen as weird/controversial/thought-provoking. :noidea:
mattr
by mattr
Mail any manufacturer of any size and you'll get pretty much the same response.
CAAD8FRED
by CAAD8FRED
robeambro wrote:
Mon Apr 08, 2019 7:38 pm
Don’t think it was meant to be, I was just putting it out in this forum for people who still like rim brakes
Beaver
by Beaver
ChiZ01 wrote:
Mon Apr 08, 2019 7:31 pm
So you are running off-road...? On the road it's really not that improvement. More expensive, heavier, less aero for a bit better modulation and braking power (wider tires help more). If you are 100kg, live in the mountains and ride in the rain regulary get disc, but for most people it's just unnecessary.
mattr wrote:
Mon Apr 08, 2019 7:41 pm
Canyon will not develop any new rim brake models... Specialized teams will only ride on disc equipped bikes... Trek and Rose will continue with rim brake development, Shimano also. It's not settled...
mattr
by mattr
So, Canyon will carry on manufacturing and selling rim brake bikes, for the foreseable future.
So will Specialized and Trek and Rose. So pretty much the same response.
Noctiluxx
by Noctiluxx
Only two pounds? You know two pounds is usually the difference between a $6K bike and one that costs half that.
2018 Bianchi Oltre XR4, (Celeste Matt)
2018 De Rosa SK Pininfarina (Blu)
2019 Trek Madone SLR (Rage Red)
2019 Giant TCR Advanced SL (Chameleon Blue)
2019 Giant Revolt Advanced 0
ChiZ01
by ChiZ01
Noctiluxx wrote:
Mon Apr 08, 2019 9:01 pm
most of the weight came from the frameset which is designed for gravel with beefed up 600g fork and 1300g frame, the difference is much less if the frameset weights the same. My old bike has 350g fork and 1000g frame
Lewn777
by Lewn777
After using mechanical and hydraulic disk brakes on motos, MTBs and CX bikes for over 20 years I hate the idea of disk brakes on a road bike. Marketing department driven marginal gains in the wet only.
Direct mount brakes, wheel rim surfaces adn rim brake blocks are still evolving.
I've got Shimano Dua-Ace on DT Swiss alloy rims, disk brakes are not better in the dry, you're just adding weight and complication for absolutely no reason, couldn't ask for better power or modulation. It's the 26inch-to 27.5inch MTB wheel American/Taiwanese manufacturer driven money grab 2.0. Most people shouting loudly for disk brakes are simply suffering from post purchase rationalization or are seeing psychological benefits. Why you'd seek add weight and complication to your bike for such marginal gains is beyond me.
Sorry to be so aggressive in my opinion, but I'm sick of this.
robeambro
by robeambro
Wow, this thread is taking such a novel and interesting spin. I don’t think I’ve ever heard these arguments, they bring such freshness to the discussion.
Following Lews777's post: I wonder, has anyone ever compared a disc brake frame with its rim brake version on alu rims?
Beaver
by Beaver
robeambro wrote:
Tue Apr 09, 2019 7:29 am
Ok, something new: What about an ecological comparison? Is it wrong to presume brake fluid doesn't shine here? Same for electrical drive trains with electric motors and batteries? Rim brakes and mechanical shifting are simply greener! :mrgreen:
kgt wrote:
Tue Apr 09, 2019 8:29 am
Tour Mag.: Dry no real difference but a bit better in the wet.
adilosnave
by adilosnave
Although I still don't have disc on my road bike (Chapter 2 Rere with direct-mount DuraAce calipers combined with Exalith rims is pretty good,) it's hard to deny how much easier it is to modulate hydraulic discs. Sure, more hassle to set up with brake fluid and the like but they don't really fall out of adjustment.
But here is what I think is missing. There needs to be a lever on the caliper to open those pads a little bit when their is rotor rub. I don't care if you have thru-axle or not, sometimes there is rub when the clearances are that friggin' tight. Maybe not such a big deal with mountain bikes since there is just so much bashing and bumping along the trail but on a smooth asphalt road? Rotor rub would drive me nuts.
Hey manufacturers, make this a thing!
