KMC X12 Chain on Campagnolo 12 speed 50 34
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
kdviner70 wrote:
Sat Apr 13, 2019 7:11 pm
wilwil wrote:
Sat Apr 13, 2019 3:48 pm
kdviner70 wrote:
Sat Apr 13, 2019 3:14 pm
ome rodriguez wrote:
Sat Apr 13, 2019 4:27 am
I use kmc missing link 12 and sram eagle 12 power link on my campagnolo 12 speed chains with no problems
Hmm - I wonder what I did wrong? I tried twice to lightly press the missing link 12 into the new Campy chain. Any tips? Just to make sure, is this what you are using?
I have just bought these missing links and notice it doesn't say Campagnolo on the packet but does on their website. There isnt a specific Campag version. I bought them to carry for emergencies because as Calnago said, theres no reason to use them with 12 speed. I have heard and I really dont know if its true that the Campag 12 speed chain is noisy and some people are using the new Sram 12 speed chains.
Ive used KMC links on Campag 11 speed with out problems but I dont reuse them like some do. KMC chains were never an improvement over Campag with 11 speed.
Let us know if they do fit. That will prove I did something wrong.
The dimension figures quoted neglect tolerances.
Campagnolo don't reveal their maxima / minima for any component dimension - so KMC are just guessing in their manufacture - if you had a Campag chain near the max of it's over-link-plate tolerance and a KMC joining link at the minimum of their pin length / joint step tolerance, it's entirely possible that you might find it difficult or impossiblle to close. 0.05mm doesn't sound like a lot in terms of pin length difference but it's still the difference between a light interference fit and a clearance fit ... as a material example, the difference required to secure an old-school headset into a frame is only 0,075 - 0.1mm and they are tight enough to need a press to insert ...
If it did close, it could fail. I have about 20 joining links of various formats I have collected over the years with various failure modes. When customers ask me why I only ever recommend them as an emergency get-you-home, I just pour out my little container of failed links.
A properly rivetted chain is exceedingly unlikely to fail but it does have to be done correctly - it's not about being in the 21st century or otherwise - it's just good engineering and correct tool use.
Please remember, if you fit a third party chain or a joining link and you suffer a failure of any sort in the transmission, Campagnolo are not bound to honour any element of the warranty on your shiny new groupset, any more than Shimano or SRAM are if you mix and match their components ... your chances of needing to avail yourself of that warrnty are very, very small, admittedly - but users do need to be made aware of that fact.
kdviner70
by kdviner70
graeme_f_k wrote:
Mon Apr 15, 2019 3:21 am
I think I under stand what you are saying. So when the Campy website states that the new 12 speed chain is 5.15 mm is that an average?
fluoroller
by fluoroller
I tried the KMC X12 chain on Record 12 speed. Had rubbing between the chain and adjacent sprockets in the 3rd and 4th gears, as the chain was too thick. Changed to the Campy R12 speed chain and problem solved.
talltales
by talltales
Calnago wrote:
Wed Apr 10, 2019 11:57 pm
gorkypl wrote:
Wed Apr 10, 2019 10:47 am
Calnago wrote:
Mon Apr 08, 2019 6:22 pm
Peen it properly. Forget the quicklink. Especially with 12sp stuff, there is no reason to break the chain.
Are you able to clean the chain thoroughly without taking it off? How? Serious question, I just always took the chain off as it seemed impossible to clean it on the bike.
Yes, but if you want squeaky sparkling clean, then no. I don't believe in getting it squeaky clean between lubes, stripping every trace of lubricant or whatnot off the chain. I use Dumond Tech Lite as my lube of choice (not the ProX stuff). I use a Park Tool Chain Cleaner with warm water and a few drops of Dawn Dishwashing liquid. Run the chain through it, rinse it with a hose, maybe take a stiff brush to the chain depending on how "sparkling" I want to get it. But the idea is just to remove and grit and grime and fine sandy particles picked up from the road. I use a tiny flat screwdriver as kind of a scraper on the pulleys to remove the gunked up stuff. Then dry it (I have compressed air), but you can just let it air dry. Then just apply a small drop to each roller bushing. Always have a super quiet drive train. I use the Park Chain Checker CC3.2. or some Vernier calipers and follow Campy's guideline of when it gets to 132.60mm, it's time to replace. As a matter of convenience, the 50% mark on the Park Chain Checker is a bit beyond Campy's guideline, but it's just easier to quickly check using this tool and close enough.
Can you provide the actual lenght of the park tool, please?
Calnago
In Memoriam
by Calnago
talltales wrote: Can you provide the actual length of the park tool, please?
The Park Tool is ~171mm (rough measure with a ruler) at the 0.5mark. That’s measuring between 14 links (distance between 15pins). The Campy guideline is when the chain is at 132.60mm (11 links, 12 pins), it’s time for replacement. The 0.5 mark on the Park Tool indicates that the chain has worn one half of 1%, and that is the wear point determined to be the time for replacement. To be clear, it does not mean the chain is 50% worn and you have 50% left. It means replace the chain now. So, if a new chain is at ~132.0mm (very close), then half of 1% of that is 0.5 x (.01 x 132.0) = 0.66mm. So, that would imply a distance of 132.0+0.66=~132.66 before replacement, or basically the equivalent of Campy’s guideline. I just find using the Park Tool much easier as a go/nogo kind of check. And yes, I can notice the degradation in shifting if I let it go much more than that, so once I can fit the Park Tool in there, I just keep it in mind to change it out at some point sooner than later.
talltales
by talltales
Yes I get all of that. I was just curious about what, exactly, park considers 0.5% or 1%. Its not a given they go by the nominal dimensions of a bicycle chain and they may or may not account for some initial slop in the rollers and/or variance in roller diameter. Btw Park just announce a new chain wear gauge that is similat tol the older Shimano tl-cn41.
PsiSquared
by PsiSquared
Late to the party as usual.....
I'm upgrading to Campy Chorus 12 speed, and I"m on the fence about what to do re: a chain. First, I wax my chains, so being able to remove a chain is essential. Is there a real, functional limit to how many times a 12 speed chain can be split and rejoined (with new pins each time)?
What is the up-to-date word on KMC 12 speed chains and their compatability or lack thereof with Campy 12? I notice that FWB lists them as being compatible. Does that mean @Madcow has tested this, or is FWB just using what KMC is telling them?
TobinHatesYou
by TobinHatesYou
I wouldn't still be waxing my chains if I couldn't use Connex links. If I buy a 12spd bike, I'd be swapping back to drip lubes for the time being.
bm0p700f
by bm0p700f
Campagnolo 12 speed chains are just not expensive enough to warrant using the kmc chain.
Wingnut
by Wingnut
Agree with you bm0700f, it's just the pin connection system that's a pain in the arse if you don't have the tool or live near a shop that does...
DaveS
by DaveS
The sram eagle 12 quick link works great. It fits better than the KMC.
Wingnut
by Wingnut
I have already purchased the Record 12spd drivetrain except for the cassette and crankset...I'll buy a Sram or KMC link soon too. I previously used Wipperman links with my 10spd which were great but yet to see a 12spd link from Wipperman?
mag
by mag
12 speed Connex Link should be available early next year
Renault78law
by Renault78law
What tool are people using to peen the Campagnolo 12 speed chain? Any tools at a reasonable price? Many of the descriptions of chain tools say they are 12 speed compatible, but for a reason unknown to me, they specifically say it can peen a Campagnolo 11 speed chain, and are silent on 12 speed. Would the peening function be the same as between 11 and 12 speed?
