Helmet fit question
wilwil
by wilwil
Ive just replaced my POC Octal with its updated model the Ventral air spin. The Ventral is a slightly closer fit and with a thin beanie underneath there is a gap between the hemet and the top of my head because the helmet doesn't pull down quite far enough. Is this usual? The Octal is the same size M but was pretty big until tightened with the adjuster, so wearing a hat under it was no problem. Without a hat the Ventral is not on the outer limit of its adjustment and fits fine.
bikerdan
by bikerdan
As far as I know the Octal in M went up to 60cm. But the Central in M goes up to 59cm
Sent from my BND-L21 using Tapatalk
