Are We Getting A New Cannondale Supersix?
mustafah009
by mustafah009
vneilv wrote:
Wed Jul 28, 2021 11:44 am
Has anyone posted these yet? Supersix EVO SE?
https://ciclimattio.com/p/supersix-evo- ... 0c63b1c8e1
I'm sure that these are just mock ups but some interesting things to note.
Looks like its some sort of AXS with a flat top chain yet it has a spidering - will Cannondale update these to run 12 speed chains? I know it can work with the older 11 speed rings but an update would be nice.
Stem looks interesting, alloy but with integrated cabling. Once again could just be a mock up but would love to see a lighter version of the current Cannondale bar / stem combo.
You can partially see it here:
Wenne
by Wenne
mustafah009 wrote:
Thu Jul 29, 2021 2:58 pm
Prosper00
by Prosper00
Any idea what size disc calliper bolts I should be using on a Sram Force AXS Supersix?
Mcdeez
by Mcdeez
2020 supersix still rolling strong,abused ,no cracks on the frame, love itImage
WorkonSunday
by WorkonSunday
Anyone seen a supersix (disc brake version) being fitted with cable actuated calipers? the ones im most intersted in is TRP HY-ROAD. thanks.
Some say pour 10ml water out of your bottle to save that last bit of the weight. Sorry, i go one step further, i tend to the rider off my bikes. :thumbup:
oldmac
by oldmac
WorkonSunday wrote:
Tue Aug 03, 2021 10:06 am
There is not enough room for TRP HY-ROAD to install at rear brake.
WorkonSunday
by WorkonSunday
oldmac wrote:
Tue Aug 03, 2021 10:48 am
ah, thats what i thought. oh well...there goes that idea. :?
thanks.
Hexsense
by Hexsense
Juintech F1 and juintech GT-F might fit. It's a lot smaller than Hyrd.
oldmac
by oldmac
Hexsense wrote:
Tue Aug 03, 2021 5:56 pm
Don't use Juintech brake on Supersix or Systemsix, it feels terrible.
That is my personal experience.
WorkonSunday
by WorkonSunday
oldmac wrote:
Wed Aug 04, 2021 3:30 am
is that Juintech in general or because of something specific about the supersix/systemsix combo ?
RDY
by RDY
The GT-F is great. Either you haven't used it, or it was horribly badly set up if it felt 'terrible'.
chase7545
by chase7545
Anyone know approximately what size di2 wires and junction boxes I would need on a 56cm Evo with a 100mm/420mm bar setup? Building up from a frameset that's still in transit but I wanted to get all the parts ready in advance.
mikemelbrooks
by mikemelbrooks
what is the weight difference between a SI and an SISL2 crank axle?
Beancouter
by Beancouter
mikemelbrooks wrote:what is the weight difference between a SI and an SISL2 crank axle?
In my experience, they are the same!
Dan Gerous
by Dan Gerous
There was only one version of the 109mm spindle originally, they later added a second version. The original and the lighter one has holes drilled out between the splines at each ends, the other version doesn't have those holes, but the material is the same, wall thickness in the middle is the same as far as I can tell so the weight difference is probably marginal, maybe not even a factor once you install it as these holes usually get filled with grease.
I'm not sure if they have two models now or if the non-drilled version replaced the drilled one. :noidea:
The ones with holes typically weigh around 63-64 grams. I have one of the other version but can't find it, I must have installed it somewhere and wont start removing cranksets just to check the weight, sorry.
