Are We Getting A New Cannondale Supersix?
nunokas
by nunokas
Is the actual spidering compatible with 12v chains?
Mcdeez
by Mcdeez
rides4beer wrote:New wheel day! LB AR56s w/DT240EXP hubs, 1455g. Need some better shots in the sun, the satin finish looks great.
Its Regular frame or hi mod? Love this color, i didnt had a big choise of colors, the flat black (the only available) is nice but i would prefere yours for sureImage
rides4beer
by rides4beer
Mcdeez wrote:
Fri Apr 16, 2021 6:37 pm
Mine is standard mod, they do have a similar paint scheme in hi-mod, main difference is the white goes all the way down the chainstay.
ccparkhill
by ccparkhill
Are you using OT-RS900 housing between the frame and rear mech? Should be much shorter than that.
treyxt
by treyxt
rides4beer wrote:
Fri Apr 16, 2021 9:08 pm
what the weight?
Mcdeez
by Mcdeez
I dont mind that loop, i by passed the external cable housing, because if i go smaller theres more tension if i turn the steering
Mcdeez
by Mcdeez
what the weight?
Just under 17 lbs with pedals and cages
rides4beer
by rides4beer
what the weight?
Mine is about 8.1kg with the stock 105 groupset and alloy post, pedals, cages and computer mount. Should be around 7.6kg after di2 and carbon seat post, plenty light enough for me, being 84kg.
Dan Gerous
by Dan Gerous
nunokas wrote:
Fri Apr 16, 2021 9:46 am
It works flawlessly with Shimano 12 speed chains and I suspect it works with Campy 12s too as the chain dimensions are not too far off.
For SRAM AXS, it works 'acceptably' in a workstand but your milage may vary under power out on the road given the slightly bigger diameter chain rollers that are meant to be used with AXS specific chainring teeth profiles/dimensions, and who knows if it will accelerate wear because of that.
nunokas
by nunokas
Dan Gerous wrote:
Sun Apr 18, 2021 6:08 pm
Thanks Dan :beerchug:
So the possibility to use it with the new Shimano is high 8)
Hexsense
by Hexsense
Mcdeez wrote:
Sat Apr 17, 2021 3:37 pm
huh? turning the bar should take the cable slack from the front end. It should not pull all the way to the rear derailleur loop.
Dan Gerous
by Dan Gerous
nunokas wrote:
Sun Apr 18, 2021 8:19 pm
I assume so, unless they have a completely different chain design than their 12 speed mountain bike chains, with different sizing as SRAM did. But by looking at their past releases where Dura-Ace usually/often uses tech first introduced on XTR, I think the odds the next gen Dura-Ace and Ultegra will work on SpideRings are good.
rides4beer
by rides4beer
I ran a Shimano 12spd chain on my last road bike with Udi2, worked great. The pin/link spacing is exactly the same, the chain is just narrower, which helps it run a lil quieter on an 11spd setup.
nunokas
by nunokas
Dan Gerous wrote:
Mon Apr 19, 2021 3:01 am
Perfect! :D
Because hallowgram chainset is the "sexiest of them all" :twisted:
Hexsense
by Hexsense
rides4beer wrote:
Mon Apr 19, 2021 2:09 pm
If the chain is stupidly narrow, it can fall in between gap of big ring and small ring. But 12 vs 11 speed chain isn't that big of a difference. And especially for Spidering, such gap between big ring and small ring do not exist.
Narrower chain slightly effect the FD shifting though.
