Are We Getting A New Cannondale Supersix?
Hexsense
by Hexsense
pmprego wrote:
Thu Oct 29, 2020 11:08 pm
Hexsense wrote:
Thu Oct 29, 2020 10:56 pm
But then you run whole length housing, isn't it?
Most adapter allow you to stop the cable housing at the adapter piece. Just run bare cable to the bottom bracket.
What adapter are you referring to?
Something like this
https://www.soigneur.co.uk/online-store/cannondalemgik
Hexsense
by Hexsense
My fitting changed (well, not really: just a new saddle require saddle rail clamp to be more forward), so now I'm looking for 0mm offset HG 27 Knot seat post in the USA.
It is annoyingly hard to find at a reasonable price right now. Sigmasports don't ship Cannondale product to USA. Cannondalespares out of stock to next year etc.
Anyone have a source?
bet1216
by bet1216
Hexsense wrote:
Thu Oct 29, 2020 11:31 pm
I have been looking since Sept. No luck. Cannondale won't even give authorized dealers and estimate. But I I ordered a 400mm SAVE systembar in August that was backordered until Dec. and it came in mid September so hard telling.
pmprego
by pmprego
Just to confirm. The supersix uses a standard 1-1/8 fork for regular stems, isn't it?
And, second question. What is the "25mm too cap" mentioned in the headset part? (from websites selling the supersix)
I've been burned so now I try to make sure of every little detail. Thanks
Jackofallgrades
by Jackofallgrades
pmprego wrote:
Thu Oct 29, 2020 5:32 pm
I'll add another question... I've been searching the thread and I saw someone stating that a 51 size can only accomodate 71cm of BB-saddle height. Can people confirm this?
My saddle height is around 75cm but that is to the top of the saddle. I guess to the rails should be some 3cm less. Still above that 71 figure...
I have a 51 with a saddle height of 70.5, and there's definitely enough margin for 75. :thumbup:
Cannondale SSEvo3 'Atticus' - 7.2kg
...Work in Progress viewtopic.php?f=10&t=161634
Dan Gerous
by Dan Gerous
pmprego wrote:
Fri Oct 30, 2020 6:31 pm
Yes, regular 1 1/8 stems.
The '25mm top cap' is a cone shaped headset spacer (see top left part below) that shipped with the older Evos, not with the 2020+ (although maybe they have it on the rim brake models).
pmprego
by pmprego
Dan Gerous wrote:
Fri Oct 30, 2020 7:10 pm
Thanks!
TheNuttyProf
by TheNuttyProf
Hi all,
Can anyone confirm if the Sram AXS issue has been resolved?
Also, what is the best cockpit to run with a slammed stem?
TIA!
Jackofallgrades
by Jackofallgrades
TheNuttyProf wrote:
Sat Oct 31, 2020 11:41 am
Hi all,
TIA!
On the Sram issue, all you need is a small spacer to fit in the Thru Axle between the cassette and the frame dropout section, it forces the stays out just enough to clear it. I've got one ready...
And on cockpit, I've got a Zipp Sprint stem which looks pretty good, there's a couple other builds on here with the same. Bit heavy though! For integrated solutions, Farsports work pretty well with the integrated spacers.
Discodan
by Discodan
Jackofallgrades wrote:
Hi all,
TIA!
That would do it nicely. How thick a spacer are you talking about, 1mm or so?
Jackofallgrades
by Jackofallgrades
I'll have to check when I'm home tomorrow, but it could even be just 0.5. Nothing major, certainly when you feel the flex capacity in the frame just giving it a pull without the wheels in.
flashpunk
by flashpunk
Jackofallgrades wrote:I'll have to check when I'm home tomorrow, but it could even be just 0.5. Nothing major, certainly when you feel the flex capacity in the frame just giving it a pull without the wheels in.
Where'd you get this spacer?
Jackofallgrades
by Jackofallgrades
flashpunk wrote:
Sun Nov 01, 2020 12:29 am
From a Cannondale rep. I haven't seen any official word on this issue, but given it's so easy to fix I'm not all that bothered... Not sure from their position why not make that announcement :noidea:
req110
by req110
Hello guys.
I have this on right side of my headtube, the paintwork is peeling off here.
It should be covered by warranty. "Paint and Decals: One year from original retail purchase."
I have contacted lbs, they told me to bring it and they will send it to distributor. I will do that soon most probably, unless you tell me there is no chance of getting replacement.
Can you guys share with me your experience?
1) is there probability of getting new frameset on RMA?
2) i bought the bike as ultegra kit, but replaced for sram red etap, i hope they won't have any problem with that
3) my frameset is 2020 team replica rapha / if i get new frameset, will they
a) find exact same 2020 team replica
b) replace with 2021 team replica
c) offer me some other hi-mod frameset
d) try to fucc me up with standard mod frameset?
#1 Cannondale SuperSix Evo Hi-Mod 2021 @ 6477g
#GR Factor LS AXS 2021 @ 83xxg
#XC Scott Spark RC 900 World Cup 2019 @ 9999g
Geraint
by Geraint
My experience of Cannondale warranties and crash replacements (I've had one of each) is that they have a stock of frames for this purpose and they offer you what they have available from that. I've had a 2018 Synapse replaced with a 2019 (nicer colour) under warranty, and when I crashed my CAAD12 disc there wasn't a like for like replacement available so I ended up with an Evo3 black inc disc frameset at less than half price, ie about £300 more than the CAAD12 frameset had cost me. I was very happy with the outcome on both occasions.
If you like that old Rapha colour then I'd question whether it's worth the hassle, it only looks like a minor cosmetic blemish to me and I personally wouldn't bother. But YMMV.
