Are We Getting A New Cannondale Supersix?
g32ecs
by g32ecs
C36 wrote:
Sun Oct 20, 2019 9:00 pm
need to swallow 600g of cockpit.
Oy.
https://tenor.com/view/spit-take-laugh-lmao-gif-9271200
novalrasidi
by novalrasidi
brearley wrote:
Tue Oct 15, 2019 10:49 pm
Is there a lighter solution to pf30a bottom bracket than the token ninja setup?
As they all seem to screw together I'm thinking none are going to be sub 100g and I'd consider full ceramic replacements to the bearings to drop weight further
I buy ROTOR PF4630 BB CERAMIC RED , its 101grams
S6ED
by S6ED
novalrasidi wrote:
Mon Oct 21, 2019 8:12 am
The stock Cannondale alloy PF30 cups are lighter than all other options, I believe.
A simple and, according to my experience of about 25.000km on my Evo2, effective solution.
jamesberger
by jamesberger
Can someone please tell me where I can order one of these?
roeman
by roeman
Does anyone have the weight of the Knot 45 SL wheelset.
Cheers
Giant XTC Team 2014
Giant TCR Advanced Pro 1 2016
Cannondale Scalpel Si 2018 Team
Cervelo S5 Dura Ace - Enve 4.5's
Dan Gerous
by Dan Gerous
roeman wrote:
Tue Oct 22, 2019 2:35 pm
Cheers
I think it's around 1575gr, not super light for a 45mm rim but not bad considering how wide it is.
Bluechip
by Bluechip
The HG 35's on the new SS are right at 1650g including axles but without discs.
flashpunk
by flashpunk
I'm going to be picking up the Force Etap build this coming weekend, and im likely going to be swapping the crank out for power (and to shave a few grams). It appears as though
Can someone confirm that I will need a crank with a BB30 spindle (without changing the bb)?
hernejj
by hernejj
flashpunk wrote:
Tue Oct 22, 2019 5:48 pm
The way I understand it, most 30mm cranks SHOULD work. BB386 EVO, and BB30 (newer/longer models should fit) are what I evaluated before I settled on SRAM Red BB30 with integrated spider. You may just need to add/remove spacers to get everything to fit without play. After picking something you can always post it here and someone should be able to tell you if it will work or not.
flashpunk
by flashpunk
hernejj wrote:
Tue Oct 22, 2019 7:27 pm
Thanks, yeah, im leaning towards the SRAM Red Axs Cranks w/power meter.
Dan Gerous
by Dan Gerous
Given you have Force eTAP AXS 12 speed groupset, the safer bet is sticking with something with SRAM AXS 12 speed chainrings. According to SRAM, their Red/Force AXS chains are not compatible with other chainrings and other 12 speed chains are not compatible with their AXS drivetrains as well... They were saying the same with 11 speed eTAP which was non-sense to convince people to buy their stuff but with AXS's chain rollers being a slightly different size, they might have a valid point this time...
But, I have seen a few bikes built with non AXS rings and chains that worked with Red or Force AXS groupsets and it works, in a workstand at least, how good and for how long though remains to be seen.
flashpunk
by flashpunk
Dan Gerous wrote:
Tue Oct 22, 2019 7:55 pm
Given you have Force eTAP AXS 12 speed groupset, the safer bet is sticking with something with SRAM AXS 12 speed chainrings. According to SRAM, their chain is not compatible with other chainrings and other 12 speed chains are not compatible with theird AXS drivetrains as well... they were saying the same with 11 speed eTAP which was non-sense to convince people to buy their stuff but with AXS's chain rollers being a slightly different size, they might be right...
Thanks yeah, thats also what im thinking. The RED AXS cranks are the way to go for sure, just not sure if i should get DUB or GXP?
Dan Gerous
by Dan Gerous
I'm guessing the bike's stock crankset is a Force DUB with a DUB PF30 bottom bracket, in which a DUB Red crankset should fit right in. I'm guessing it's DUB as it would make little sense for Cannondale to spec the bike with a GXP has it has no advantage over a lighter and stiffer DUB on any bikes that can fit DUB.
Discodan
by Discodan
I believe the maker uses the tag Kimchi Mechanic or similar and is out of Korea. I don’t know if anyone has had any luck being able to order them internationally
jamesberger
by jamesberger
Discodan wrote:
Tue Oct 22, 2019 10:04 pm
Thank you Discodan!
