Are We Getting A New Cannondale Supersix?
S6ED
by S6ED
bibirider8 wrote:
Tue Sep 17, 2019 9:05 pm
S6ED wrote:
Tue Sep 17, 2019 1:05 pm
bibirider8 wrote:
Tue Sep 17, 2019 9:09 am
From France
Dura Ace Di2, Mavic Cosmic Carbone, Fabric Scoop, combo bar stem Knot, Time pedal
Weight 7.4kg on size 54
Nice! What is the bottom bracket to top of saddle height?
Sorry it's not my bike, but i can try to ask at the owner
OK, thanks!
hernejj
by hernejj
If I'm planning on buying a SS Evo 105 and upgrading it to Ultegra DI2, does anyone know if the BT-DN110-A battery fits in the seatpost? Does the D-shaped seatpost come with some type of di2 battery mount/adapter? Do I need to buy one of the Shimano mounts (BM-DN100-S, BM-DN100-L, BM-DN100-I)? Thanks :)
Dan Gerous
by Dan Gerous
Cannondale has a Di2 battery mount specially designed for the seatpost, it clips at the bottom of the battery and is shaped to squeeze against the flat section of the seatpost.
I'm not sure if it comes in all the bike's spare parts bag or not but dealers 'should' be able to order it if it doesn't. It's called 'KNØT 27 Di2 Battery Mount' part number is K32180... Otherwise, all the tricks that work on round seatposts could also do the job, it just needs to be squeezed in tight in the post.
S6ED
by S6ED
As an owner of an Evo2 Disc bike (size 54), I'm thinking of eventually upgrading to the Evo3 frameset - but which size?
My BB-to-top-of-saddle height is 74cm and I've set up my current bike with a 120mm, -20deg stem, totally slammed. A 110mm stem would perhaps suit me better.
Should I go for size 54 or 51?
Thanks in advance for the advice.
Dan Gerous
by Dan Gerous
Got the official specs for the SuperSix SAVE bars, they're not the same as the SystemSix KNØT bars but can be mixed and matched.
SuperSix Evo SAVE bars:
SystemSix KNØT bars:
Dan Gerous
by Dan Gerous
S6ED wrote:
Wed Sep 18, 2019 7:43 pm
I'm also on a 54 with a 74cm saddle height... but in my case, I use a -6° stem with 10mm of total stack between the stem and frame, I have more wiggle room than you do and I would go with a 54 with the Evo 3. The new 54 has a 3mm higher stack and 3mm shorter reach than the Evo 2 so, with the KNØT cockpit if I would keep that, I would just use one 7.5mm spacer and would have pretty much the same fit.
The 3mm difference is quite small if you keep your -20° 120mm stem. If you use the KNØT setup, there is a -17° stem option which, slammed, would still put you higher on a 54 than your current setup so then, maybe a 51 would work better, it has a 9mm shorter reach than a 54 Evo 2 but with a 17mm lower stack. If a 110mm stem would be better, a 120mm on a 51 would be good and the fork rake/trail geometry of the 54 and smaller new Evos probably works better for those who need longer stems because they ride smaller frames to get low, your weight wouldn't be as much over the front wheel as before, more balanced between the two wheels.
Disclaimer, I'm no bike fitter. :mrgreen:
S6ED
by S6ED
Dan Gerous wrote:
Wed Sep 18, 2019 8:29 pm
Thanks for your input. I have to admit that I do not like the looks of a -20deg stem (see photo), so I'd rather use a more conventional -8deg stem. Given that, the 51 frame would perhaps be better as it would allow me to dial in a low position with a "normal" stem.
One concern would be, whether the seat post is long enough the get the 74cm saddle height with the 51 frame.
Dan Gerous
by Dan Gerous
S6ED wrote:
Wed Sep 18, 2019 8:57 pm
Should be fine. The seatpost is 330mm long with 65mm minimal insertion, so if you put it as high as it will go on a 51 which has a 47.7 seat tube length, the rails would be at 74.2cm... so that's still higher than you need without even adding the height of the saddle.
S6ED
by S6ED
Dan Gerous wrote:
Wed Sep 18, 2019 9:09 pm
Thanks. So I may have a plan regarding my next bike investment!
By the way, do you perhaps have any info regarding future colour schemes for framesets? So far, there's the black-purple "team" design and also the rather luxurious "champagne" design, both of which are somewhat an acquired taste...
S6ED
by S6ED
Deda Vinci stem, compatible with internal cables.
http://www.dedaelementi.com/en/vinci/
hernejj
by hernejj
Dan Gerous wrote:
Wed Sep 18, 2019 7:31 pm
Awesome, thank you for that info! :)
Spinnekop
by Spinnekop
Anyone found out what the part number on the cabon seatpost is? Can't find on the website and local dealers are not that clued up or they just dont want to earn $$.....
Thank you
"In my experience, there is only one motivation, and that is DESIRE.
No reason or principle contain it or stand against it........"
nooski
by nooski
K2601000 Carbon 0 mm offset
K2601015 Carbon 15 mm offset
K2602015 Alloy 15 mm offset
Dum spiro spero
my bike: viewtopic.php?f=10&t=130302
Spinnekop
by Spinnekop
nooski wrote:
Thu Sep 19, 2019 9:33 am
Thank you kind sir. :thumbup:
Bluechip
by Bluechip
Does the 2020 Synapse use the same type of bars as the SystemSix and SuperSix on the high end models? It looks like a traditionalish stem that accepts the flat mount bar. It just wont hide the cables. It might be an option for those that don't like that huge stem. It could be lighter too. Doesn't help with the weight of the bars though.
