Are We Getting A New Cannondale Supersix?
skyliner1004
by skyliner1004
furiousferret wrote:
Tue Aug 20, 2019 4:18 pm
I've been looking into cockpit options for a 105 disc and I really want to have the cables hidden. I know 2 options are the Metron and Knot, but the Metron isn't as 'clean' and then Knot is heavy.
666pounder wrote:
Tue Aug 20, 2019 1:08 pm
Was watching Tour of Utah yesterday and it's interesting that Joe Dobrowski was riding his old Supersix.
Dombrowski is a pure climber both mentally and physically. He's going to take the lightest bike going in, and the new gen isn't as light. I don't think its necessarily a knock on the new bike.
Rant: I find it depressing af we can't find an American cyclist good enough to win our home races. The Pro Tour races outside of Western Europe typically have someone from the home nation good enough to win (see Tour Down Under, Tour of Norway). USA Cycling is a mess.
https://www.merlincycles.com/3t-ernova- ... 16066.html
I use this on my 2018 and it has internal cable routing, weighed 198g
To reply to your rant, cycling simply isn't big enough in america. Americans like "big hits" "fast fast fast (sprints, strength, muscle, fireworks)," "i beat you by x points!"
Yes, i'm american and watch football, ufc, etc.
2018 Supersix Evo Hi-Mod Disc Dura-Ace
Conti SS + Gp5000
3t Ernova Team
Garmin 520 Plus
Look Keo Blade 2 Carbon Ti
15lb 15oz
GrumpyOldPizza
by GrumpyOldPizza
IMHO the UCI limit of 6.8kg would apply to both the EVO 2 and the EVO 3. Looks like even the disc version of the EVO 3 can get down to this limit. GIven that, Joe picked the EVO 2 over the EVO 3 because it would do the job better for him.
GrumpyOldPizza
by GrumpyOldPizza
skyliner1004 wrote:
Tue Aug 20, 2019 8:11 pm
Perhaps it would help if the power, cadence and heart rate data would be available to the spectator. One could compare data and "he beat him by x watts on the climb" ...
Discodan
by Discodan
In the hunt for an integrated bar that will allow the best integration of the cables for the SS, the best option I can see so far is the canyon cockpits. I’m leaning that way because they have a cavity under the stem (for the di2 box I think) that would let you exit the cables just in front of the steerer where it could drop down into the cable port. This would require a shim as the canyon stem is built for a 1 1/4 steerer but that’s easily available
I’m planning to firstly see if I can shape one of the SS spacers so that it blends into the underside of the stem but need to see if that’s feasible. Worst case involves learning how to model in 3D and printing up a custom spacer that transitions from the SS spacers to the underside of the stem
What’s the chance someone has a canyon cockpit and a ss spacer sitting around and could take some photo’s?
refthimos
by refthimos
Discodan wrote:
Tue Aug 20, 2019 11:31 pm
A while back, I went ahead and bought the eBay bar I linked to above (thinking I might put it on my SystemSix). It looks like a copy of the Canyon Aerocockpit CF. I found that the plastic pieces underneath the bar that keep the cables in place were pretty rough on the hands, unless you wrapped the middle section, but that's not something I do with aero road bars. Maybe the Canyon is different/better than the eBay bar, but even looking at a photo of the underside of the real Canyon bar below, it seems like a bit janky cable routing, which is perhaps not surprising since the Aeroad doesn't have integrated cable routing like the EVO3 and all the photos you see of the Aeroroad show the cables exiting the bars in their usual place, not at the top of the head tube:
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
Shiv Tri Disc | AXS | SISL2 P2Max | Enve 7.8 | Ascalons/Titan/Aeox Utimate Disc coming
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
refthimos
by refthimos
Meanwhile the Syncros Creston iC SL is supposed to be lighter than than the Canyon bar and is designed to support full cable management:
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
Miles253
by Miles253
refthimos wrote:
Wed Aug 21, 2019 2:06 am
It's really nice looking. What I can't figure out is what it's all going to look like using a proprietary bar for another bike, on your bike. It's something I'm considering for my Venge.
Surely the spacers and such don't line up or create some edges etc.
Specialized S-Works Venge Disc | 7.8kg
Rose Backroad | 9kg (Deceased R.I.P.)
Canyon Ultimate CF SL | 7.7kg
https://www.findyourroad.co.uk/
Instagram: @miles_bc
robeambro
by robeambro
Scott managed to design such a better looking product than Cannondale did. Just y'all look at these two.
aeroisnteverything
by aeroisnteverything
refthimos wrote:
Wed Aug 21, 2019 1:57 am
I have the same thing. I eventually dispenced with those plastic pieces - you don't need them. Just a bit of electrical tape on the underside and the bar tape where the indented part ends is sufficient to hold cables in place.
I like this bar, a lot. It's comfy, has a nice shape to grab anywhere, and stiff and light enough. That said, I am not convinced whether it can produce a fully integrated design, or how it would look like on a non-canyon bike. It's the small bits: will you be able to fit the supplied cap with their screw into the expansion plug, do the cable exit the underside channel in the right spot, and what do you do with spacers. Also, on my bike, the channel under the stem is occupied with the Di2 junction box, for which it is perfectly sized to fit snugly and with no extra support. Not sure how it would work with cables or what you do with Di2 then (unless you have the newer version that fits into the bar end. Anyway, it's plausible, but needs some careful thought and testing.
TomSte
by TomSte
floriansantana wrote:
Thu Aug 15, 2019 10:38 am
Down to 7,2 kilos.
That thing rides like a charm. And is really light.
And the paintjob is crazy cool, because the grey part is not just grey but shines in rainbow glow in different angles.
@floriansantana: Could you please tell us what handlebar you are using?
Dan Gerous
by Dan Gerous
robeambro wrote:
Wed Aug 21, 2019 11:36 am
Cleaning the headset will be loads of fun with the Scott, so is travelling... :|
furiousferret
by furiousferret
While all this stuff is designed proprietary, it does seem like if you got a Syncros cockpit and threw it on your Evo, one could design a good transition spacer to make it look clean.
I'm not sure how much that would cost to send it to a shop and have them figure it out, but it would be worth it to eliminate the janky look.
Also, how many grams are we talking for a weight penalty for the Knot cockpit? They don't post the weights anywhere.
Dan Gerous
by Dan Gerous
Wed Aug 21, 2019 4:19 pm
Someone could 3D print some spacers... Thought about that, for the Canyon bars... I'd rather have the wires/hoses in an accessible recess and not fully internal like the Syncros, much easier to put it in a bike box. Plus I don't like the Y shape of the Syncros, the Canyon looks much nicer IMO.
The KNOT cockpit weights were posted a while ago, 288.8gr for the stem/bolt/spacers and 292.6gr for the bar, taken off a 56 or 58 bike... :shock: That's why they don't mention it! :mrgreen:
refthimos
by refthimos
In fairness to Cannondale, the Knot cockpit:
(1) Makes travel / servicing your bike easier
(2) Makes it easier for dealers and consumers to get the correct fit - two piece system vs one piece system is inherently more flexible
(3) Is less expensive than integrated carbon cockpits
But it sure is heavy!
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
floriansantana
by floriansantana
TomSte wrote:
Wed Aug 21, 2019 1:20 pm
Down to 7,2 kilos.
Yeah, it’s a 3T Superergo Team Stealth. Cable routing is all inside until the very middle of the bar besides the stem which makes the routing very clean. And it’s sub 200g for a 42cm width.
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
