Are We Getting A New Cannondale Supersix?
Pinguin
by Pinguin
furiousferret wrote:
Sat Aug 17, 2019 7:10 pm
I've been conflicted for weeks about 105 Disc vs. Rim. I have a new eTap 22 group on my current EVO which I want to move over, but that means if go disc I have to get new brakes and shifters. Adding to that I have to get a nice wheelset (which can wait til next race season). So that means a disc build will be about $3000 than rim.
It would be nice to get those disc wheels for BWR (which would go on my CX bike) and I do feel like rim brakes will be gone in 3 years. Either I'm going to bite the bullet today or in the future and whatever I wheelsets I buy for this bike I won't be able to carry over.
The only time I ever hit the podium in races is in Hillclimbs or races with Cat 2 climbs or more, so that's important to me. While its not so important I'm willing to spend thousands for a few extra grams, I do want to keep the build under 7.5 kilos. It seems like that's doable.
We're a Giant, Cannondale, Scott, and BMC Shop (where I get nice discounts) so I may hold out for the new Addict but ultimately I believe that's disc brake only.
You can buy the Ultimate Addict Frameset and use your Red 22 mech
Only buy Hrd Shifters and you get a very light bike under 7 kg
novalrasidi
by novalrasidi
Hello, I have ordered this bike, please help me choose the best size between 48 and 51, my height is 170cm, height from bb to saddle is 69.7cm, I order size 51 but can still be changed to size 48, thanks a lot guys 🙏
Btw I order the goldfinger ultegra disc version, hope the colour is good, I only see the colour through web, the bike is not yet available to be seen directly here.
Stendhal
by Stendhal
At a LBS today, a customer came in to try the prior model (2018) Supersix -- the store is selling at a 40% discount, $2400 as I recall for Ui2!
Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\Aspero\R5, Felt Z25, Klein Quantum, Cannondale 2.0
floriansantana
by floriansantana
Stendhal wrote:
Sun Aug 18, 2019 7:00 am
Yeah, no one should be buying a two year old bike with rim brakes and probably alloy rims for 4000$ anyway.
Cannondale SuperSix Evo Disc
Cannondale SystemSix HiMod Disc
@floriansantana
Lieblingsleguan
by Lieblingsleguan
SashaJoseph wrote:
Sat Aug 17, 2019 8:16 am
2) some reviewers complain about the cable integration limiting the angle at which the bars can be turned
Is that the same for the people here not using the integrated fugly-bar?
What happens in the event of a crash then? Cables snapping? Something worse?
Lieblingsleguan
by Lieblingsleguan
Double post...
nemeseri
by nemeseri
novalrasidi wrote:
Sun Aug 18, 2019 5:09 am
You will be fine on both of them, it's more like a question of flexibility and personal preference. In general, you can just check out the reach and stack of your current bike and the new supersix and compare the two frames by yourself.
Based on you saddle height I'd say that probably the 51cm would be a better fit (especially with the stock stem), unless you like to get real low. I'm 169cm and my saddle height is 68cm. I own a second generation supersix in 48 and I'm super happy with it. I'd also get the 48cm from the new one, but I enjoy riding bikes with longer stems and to have some wiggle room with handle bar reach.
furiousferret
by furiousferret
So it looks like I'm going with a 105 disc. I was able to get a good deal on eTap HRD and Red brakes, so now its just swapping out the cockpit and get a new wheelset (which can wait until next year when race season starts.
I'm also tempted to to keep the 105 parts and buy an Allez Sprint....not sure the wife would go for that though.
I'm about 1cm taller and going with the 48. The geometry is so different its really hard but I have a 50 Super6 Gen 2 now and the Stack and Reach is similar. I'm not sure if it still applies, but the rule has always been, 'if you're not sure, go smaller' in regard to bikes.
Hexsense
by Hexsense
I'm 169cm tall (68.9cm seat height), and there is no way i'll go for 51.
The 48 is almost too tall on the headtube already. From my calculation, i'll need -17 degree stem (ideally 115mm long, but likely round down to 110mm) and up to 7mm of head set cap+ spacer underneath. Most short headset-cap are around 6mm tall, So just a single 1mm spacer in between short headset cap and the stem. With size 51 being 15mm taller on the head tube. I can not setup my ideal position on size 51 even without headset cap.
novalrasidi
by novalrasidi
nemeseri wrote:
Sun Aug 18, 2019 5:55 pm
I don't plan to use stock stem and I like to get real low, my previous bike headtube lenght is 12cm, and new supersix evo 51 is 13cm, its already 1cm taller (same setup slam stem), I think I'm going down to size 48 (11.4cm headtube lenght), thanks for the answer 🙏🙏🙏
novalrasidi
by novalrasidi
[quote=furiousferret post_id=1512625 time=1566161135 user_
[/quote]
Allright, thank you I am making changes to the order 51 to 48 size
novalrasidi
by novalrasidi
Hexsense wrote:
Mon Aug 19, 2019 12:13 am
thanks for the info, I'm pretty sure now going down to 48
666pounder
by 666pounder
Was watching Tour of Utah yesterday and it's interesting that Joe Dobrowski was riding his old Supersix.
furiousferret
by furiousferret
I've been looking into cockpit options for a 105 disc and I really want to have the cables hidden. I know 2 options are the Metron and Knot, but the Metron isn't as 'clean' and then Knot is heavy.
666pounder wrote:
Tue Aug 20, 2019 1:08 pm
Dombrowski is a pure climber both mentally and physically. He's going to take the lightest bike going in, and the new gen isn't as light. I don't think its necessarily a knock on the new bike.
Rant: I find it depressing af we can't find an American cyclist good enough to win our home races. The Pro Tour races outside of Western Europe typically have someone from the home nation good enough to win (see Tour Down Under, Tour of Norway). USA Cycling is a mess.
refthimos
by refthimos
Tue Aug 20, 2019 4:18 pm
My EVO3 Disc is on its way and I plan on replacing the Knot cockpit as well. Other options for a bar/stem that route cables internally to the front of the head tube are the Wilier Alabarda and the upcoming Syncros Creston iC SL (featured on the Addict RC Ultimate). Assuming the Creston features a 1 1/8" clamp diameter, that's the leading contender for my bike. I couldn't get that info out of Syncros - they said they couldn't provide until November.
Another option would be something like this: https://www.ebay.com/itm/Carbon-T800-In ... x0owyaWGjQ
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
Shiv Tri Disc | AXS | SISL2 P2Max | Enve 7.8 | Ascalons/Titan/Aeox Utimate Disc coming
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
