RocketRacing wrote: ↑Tue Sep 03, 2019 3:23 am
My math from the numbers on the video shows the red crank + force spider/chainring s 133g lighter than a force crank with the force chainrings. So the force cranks/spindle are 133g heavier than red.
The numbers are in the video description.
You can also buy PM spiders and cranks separately from Quarq interestingly enough.Here are the weighed weights:
Force crank complete 46-33 teeth - 710 g
Force Spider Spider with Red Crank / Crank Arms - 577 g
(Comparable Sram Red Crank 46-33 Teeth - 564 g)
Force cassette 10-28 - 231 g
(Comparable Sram Red Cassette 10-28 - 180 g)
Rear derailleur without battery - 300 g (275 g Sram Red)
Front derailleur without battery - 152 g (143 g Sram Red)
Battery 25 g
Force Chain 273 g (250 g Sram Red)
Front brake lever incl. Cable and brake caliper 397 g (375 g Sram Red)
SRAM RED/Force AXS™ Power Meter Spider 107BCD
Quarq DZero DUB Crank Arm Assembly
SRAM RED D1 24mm Crank Arm Assembly
Code: Select all
other part numbers:
00.6218.014.006 CHAIN RING ROAD 36T 107BCD X-SYNC BLAST BLACK
00.6218.014.007 CHAIN RING ROAD 38T 107BCD X-SYNC BLAST BLACK
00.6218.014.008 CHAIN RING ROAD 40T 107BCD X-SYNC BLAST BLACK
00.6218.014.009 CHAIN RING ROAD 42T 107BCD X-SYNC BLAST BLACK
00.6218.014.000 CHAIN RING ROAD 44T 107BCD X-SYNC BLAST BLACK
00.6218.014.001 CHAIN RING ROAD 46T 107BCD X-SYNC BLAST BLACK
11.6118.062.000 CRANK SPIDER RED/FORCE D1 107BCD (NO POWER METER, INCLUDING 8 TORX MOUNTING BOLTS)
11.6918.004.001 CRANK CHAINRING BOLT KIT 4-ARM 1X RED/FORCE D1 ALUMINUM BLACK
00.6218.016.000 CHAIN RING ROAD 48T DM X-SYNC AERO BLAST BLACK
00.6218.016.001 CHAIN RING ROAD 50T DM X-SYNC AERO BLAST BLACK
00.6218.015.002 CHAIN RING ROAD 46T 107BCD 2X12 FORCE POLAR GREY WITH COVERPLATE
00.6218.015.003 CHAIN RING ROAD 48T 107BCD 2X12 FORCE POLAR GREY WITH COVERPLATE
00.6218.015.000 CHAIN RING ROAD 33T 107BCD 2X12 FORCE BLAST BLACK
00.6218.015.001 CHAIN RING ROAD 35T 107BCD 2x12 FORCE BLAST BLACK
11.6918.004.000 CRANK CHAINRING BOLT KIT 4-ARM FORCE 2X 107 BCD CRANKS D1 ALUMINUM BLACK
