rims Inner/Outer Width?
petosagan
by petosagan
hi,
i have a cannondale super six evo 2018 and I dont know if a rim can be too wide for my bike ?
I want to buy : Inner/Outer Width : 21mm/28mm, maybe it could be ok but max with 25mm tire?
thanks
Beaver
by Beaver
You should be fine, as the second generation SuperSix Evo doesn't have the clearance issues of the first generation (real 25mm tire width only).
Maybe even with a 28mm tire on that rims, depending on tire model (Conti GP 5000 will work).
petosagan
by petosagan
Beaver wrote:
Sun Mar 24, 2019 8:49 pm
ok nice
thanks... anyway light bicycles have 2 choices... 19 or 21 inner.. maybe im better with 19.. so almost every 25 and some 28 will work..?
Dan Gerous
by Dan Gerous
I have the same frameset and with Enve 3.4 wheels (27.5mm external width, 21mm internal), clearance is generous, 28mm tires fit with room to spare.
ND4SPD
by ND4SPD
Cannondale says 28 mm tyres can be mounted to Supersix (second generation).
petosagan
by petosagan
Dan Gerous wrote:
Sun Mar 24, 2019 10:06 pm
good, you mount which tires in 25 and 28 on that?
Dan Gerous
by Dan Gerous
petosagan wrote:
Sun Mar 24, 2019 11:18 pm
I tried Vittoria Corsa G+ 28, Conti GP4000IIs 25 (they actually measured a tad over 28) and now Conti GP5000 25.
Beaver
by Beaver
petosagan wrote:
Sun Mar 24, 2019 9:23 pm
ok nice
19mm inner width is ok for 23mm tires, but if you know you will use 25+mm tires only anyway, you should pick the 21mm inside width (wich will also accept 23mm tires, but they are not that easy to mount).
petosagan
by petosagan
ok nice
Yep. I use Vittoria open corsa 25..
Gp4000 ll 25. Scwalbee one 25.
Envoyé de mon SM-A530W en utilisant Tapatalk
