ZTTO 11-36T(235g), 11-34T(228g), 11-32T(216g) 11s cassettes
ooo
by ooo
ZTTO SLR2 11s cassettes advertised weight @ ali link:
11-36T: 11-13-15-17-19-21-23-25-28-32-36, about 235g
11-34T: 11-13-15-17-19-21-23-25-28-31-34, about 228g
11-32T: 11-12-13-15-17-19-21-23-25-28-32, about 216g
11-28T: 11-12-13-14-15-17-19-21-23-25-28, about 208g
All cog sets are different to shimano/sram (except 11-28T):
Nozes
by Nozes
Very nice!
I'm keeping an eye on those.
It looks very new even on Aliexpress,within a few weeks many others stores will have it for sure.
prebsy
by prebsy
I'll definitely be getting an 11-34. Does anyone know if they are using 11s road spacing through out or are they doing the overhang 10s spacing on the 11-34 and 11-36
deepakvrao
by deepakvrao
The 11-36 is 130 grams lighter than a SRAM? Thats amazing. Is this a know brand?
Marin
by Marin
The Sram 11-36 is a boat anchor though. Compare with the Sram XX1 10-42 or 10x 11-36.
The Zitto is half aluminum which might be too fragile for the medium cogs.
addictR1
by addictR1
Darn would be interested in the 11/36 for 10 sp. would it be possible to use this but not install the smallest cog and use the 11sp spacer on my 10sp?
If so would a wifli mid cage support the 36t? Or is that wishful thinking?
Marin
by Marin
addictR1 wrote:
Fri Mar 29, 2019 7:02 am
For 10s, get an 11-36 XX1 Sram MTB cassette. There are good used deals for ones with not too much wear. They are very light and full steel except for the 1st cog.
On my 10s Sram bike, my Apex Wifli derailleur has no problems shifting an 11-36, I use it every day, basically in 1x mode because there's no reason to shift down from the 46t ring with this cassette.
ooo
by ooo
prebsy wrote:
Thu Mar 28, 2019 3:14 pm
I have asked them about compatibility with 10s hubs, it is not supported yet, but they will consider it in the future.
Nozes
by Nozes
I have bought one in 11-32 last weekend, will report here as soon as it arrives.
57, 09€!
Enviado do meu G3311 através do Tapatalk
wfcarrot
by wfcarrot
The old version has a bad review on Amazon. Hope this new product could change it.
2018 Sworks Tarmac SL6 - 7.2kg
2017 Colnago C60 - 6.29kg
Brynhildr
by Brynhildr
Somebody on reddit said that they bent one of their ZTTO cassettes, dunno which model, but that kinda put me off.
addictR1
by addictR1
Thanks Marin.
But for 11/42 then wifli might not be long enough with 46T front?
Marin
by Marin
I don't think a Wifli will shift a 42t cassette. Front chainring is irrelevant and will only affect chain length.
Marin
by Marin
New 9-34 cassette BTW: https://r2-bike.com/ETHIRTEEN-Cassette- ... 9-34-teeth
MTB gear spacing though, if you compare to a 3t bailout (which is also mabe by e13).
MayhemSWE
by MayhemSWE
They do have an all-steel cassette which looks to be machined in a similar way to Sram's X-Dome construction. Costs a lot more though and so far only available in 11–26T and 11–28T for 11-speed.
https://www.aliexpress.com/store/produc ... 33e7dxFgst
If you're looking for larger cassettes for cross or MTB they have some interesting options as well. These look to have a large part of the cluster machined in one piece, then the largest two or three cogs pinned to the spider. 11-speed is all steel while on the 12-speed the largest cog is aluminium.
https://www.aliexpress.com/store/produc ... 1afdMnSwxg
https://www.aliexpress.com/store/produc ... 7fbfV7qPQZ
