Stages PM grossly over-reading
alanmclean
by alanmclean
Hi
My single crank Stages PM is suddenly grossly over-reading.
It's about three years old Ultegra version and has worked flawlessly through wet winters. Garmin 520 is working fine.
It's suddenly reading far above what it should. Cruising at 700W and climbing at 1400!
I've recalibrated/zeroed a few times with "successful calibration" at 895 usually recorded. But then it immediately over-reads.
I took battery out for an hour in the hope of resetting.
Can't see anything on Stages FAQ.
Anyone have any suggestions before I send it for servicing? Could it be the Garmin?
Regards
Alan
mattr
by mattr
Is the garmin reading it twice? Assuming its a dual sided stages?
try un pairing completely and repairing
or is it possible to reflash software? (Or even use the app to see what it's sending out?)
alanmclean
by alanmclean
Thanks
Single crank, I'll try unpairing.
will it send out to a phone?
mattr
by mattr
Yeah. Should connect to the stages app.
Or try another one of the (free) apps.
Jugi
by Jugi
Yes, it connects to smartphones via Bluetooth Smart. The StagesPower app is available for iOS and Android.
mcfarton
by mcfarton
If all else fails contact stages. They fixed mine and upgraded it to a 3rd gen for free. I did have to jump through some hoops but not to bad.
dim
by dim
Upgrade your Garmin to the latest version of software ....
un pair your stages, then recconect, calibrate, the ride and see if it has rectified the problem
Trek Emonda SL6
Miyata One Thousand
CrankAddictsRich
by CrankAddictsRich
I had a Gen. 1 DA9000 Stages that was literally doing the exact same thing you're reporting, last September.... nothing would fix it. I ended up sending it to Stages and they repaired it and upgraded it to a Gen. 3... they did charge me a little bit, because it was well out of the warranty period, which I thought was perfecty fair.
alanmclean
by alanmclean
Thanks all. I realised that I had not updated the stages firmware for years so I've firstly done that via my phone. I'll check I have latest Garmin version too. If it is still faulty then I'll return to stages. Report to follow.
onemanpeloton
by onemanpeloton
CrankAddictsRich wrote:
Sat Mar 16, 2019 11:56 pm
I have the same model. Mine is also well behaving exactly the same but when I contacted the UK stages dealer, I was told they wouldnt replace it even for a fee. All they did was offer me a poor discount on a brand new one. May I ask how you contacted stages and what price they charged you? Sorry for the hijack
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
ryanw
by ryanw
Can you try and pair with a friends device to see if still over-reading?
'16 Cervelo S5 - 6,650g RIP
'17 Focus Mares Force 1 - 7,170g
'19 Cervelo S5 Disc - 7,460g
IG: RhinosWorkshop - Check it out for all my custom builds :thumbup:
:!: Ride Southern Spain Cycling Holidays *£445 for 7 Nights* :!:
CrankAddictsRich
by CrankAddictsRich
onemanpeloton wrote:
Mon Mar 18, 2019 11:09 am
I called them directly.
alanmclean
by alanmclean
I received very quick reply from Stages support. I sent some diagnostic shots of the PM and from the >Tools page of the Stages app.
It seems the PM is confused about crank length. They've given detailed instructions on how to reset crank length which I can apparently do myself via Stages app. (needs to be android and not apple phone) I hope it means that the PM itself is ok and it's just a simple calibration problem.
onemanpeloton
by onemanpeloton
Will be interested to hear how you get on!
2017 Giant TCR Disc
2015 Giant TCX
FIJIGabe
by FIJIGabe
You can open a ticket through the Stages support website. They will walk you through the diagnostic process and provide you with instructions on replacing the crank arm (be it under warranty or by paying the upgrade). Once I had my PM, I never had to go through the dealer, again - and they may just be trying to get you to buy a new PM from them.
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Madone 5, Cobia. I own a lot of Treks.
