Does the rear Campag DB come with mounting hardware
ParisCarbon
by ParisCarbon
As the topic says... building my Venge with EPS 12, but noted there were various lenghts ofhardware to mount to the frame depending on thickness of chainstay... is there any hardware at all included though..if so, what length?
The hardware is cheap, but I want to get appropriate now rather than later...
Thanks
Miller
by Miller
Nope. The front hydro caliper comes with bolts, the rear does not. You need to source them in the correct length yourself.
bm0p700f
by bm0p700f
campagnolo do list the bolts in various lengths. the length you needs depends on your setup.
ParisCarbon
by ParisCarbon
K Thanks guys.. from reading the charts I just measure from the lower bolt mount surface to the flat mount at the top where the brake will sit, and then the table adds 5mm to the bolt length... order that bolt... Not sure what my Venge measure, will need to do that...
