Question on Giant TCR
addictR1
by addictR1
considering a TCR. anyone know what's the widest tire and rim i can fit on the 2018/2019 TCR ADVANCED SL 0?
i'm running tubular wheelset, so wanted to make sure i have plenty of clearance. thanks~
shotgun
by shotgun
sharing my experience on reynolds attack wheels
rear GP4 ii 28mm - lots of clearance
front GP4 ii 28mm - barely any, it'll rub if there's mud/dirt on the tire
2018 Giant TCR Advance SL0 Disc
2017 Festka Scalatore
1989 Battaglin Roche
1985 Alan Carbonio
sharkman
by sharkman
Same here rear is 28 max for most tyres except conti, front 25 where conti will cause damage when gravel is on them.
Bike imho rides best with good 25 tyres (at the moment corsa graphene is on the reynols wheels)
Verzonden vanaf mijn iPhone met Tapatalk
ND4SPD
by ND4SPD
There is already thread about that:
viewtopic.php?t=149170
and some more pictures of 28mm tyres on TCR:
Bear in mind that Continental Grand Prix 4000 S II are 30+mm tyres... So some 28 tyres from other manufacturers would have bigger clearance...
jlok
by jlok
I would mount 29mm max effective width tires only on my SL Disc. 28c GP4000S2 was too big and too close to the chain stay. Didn't bother to try the front fork.
addictR1
by addictR1
thank you all for the comment. good to know there's options to run wider tires. :)
chupster98
by chupster98
28mm Conti 5000 on SLR1 wheels (17mm) fit OK front & back
The 5000 are true 28mm tires, they replaced an old set of Conti 4000 iiS - 25mm with a real size of 27.5 mm mounted on the same wheels
2016 Giant TCR Advanced SL
2012 Giant TCR Advanced SL Rabobank
2014 Santa Cruz 5010 CC
integration
by integration
chupster98 wrote:
Mon Oct 28, 2019 3:15 am
Thanks for posting those pics, really helpful! Guess it's best to go with GP5000 for 28mm since it runs more true to its size.
nismosr
by nismosr
Rich guess depends on the tire I'm running Vittoria Corsa 28mm and plenty of room on my 2018
- 2018 Colnago V2-R TNMR - Campagnolo SR EPS - Lightweight Gen III - P2Max
- 2017 Colnago Concept CHDB - Campagnolo SR EPS - Bora One 50 - Deda Superzero - Stages
- 2015 Cipollini RB800 - Campagnolo Athena EPS - Bora One 35 - P2Max
itsacarr
by itsacarr
30mm tires on some super wide wheels 😬 // TCR Disc
