Vittoria Graphene 2.0
I set my pair on Light Bicycle rims with a floor pump only on the first go, super easy setup.Stitchking wrote: ↑Tue Mar 19, 2019 10:05 amHas anyone managed to set up the corsa tubless tyres succesfully? Tried to mount a pair on a set of zipp 404 disc wheels and they just refused to inflate. Never had issues with any other tyre like this. Yhe casing seemed super loose on the rim and i couldnt get it to hold air no matter what. I even pulled the valve core out and used a gun tip on my compressor to try and seat the bead. No joy
Went back to a new set of gp5000 tl and they beaded up with a charger pump no problems.
Sent from my SM-G935F using Tapatalk
you perhaps need another layer of tape?Stitchking wrote: ↑Tue Mar 19, 2019 10:05 amHas anyone managed to set up the corsa tubless tyres succesfully? Tried to mount a pair on a set of zipp 404 disc wheels and they just refused to inflate. Never had issues with any other tyre like this. Yhe casing seemed super loose on the rim and i couldnt get it to hold air no matter what. I even pulled the valve core out and used a gun tip on my compressor to try and seat the bead. No joy
however, add 30ml of Orange sealant per tyre, give them a few spins, then pump them up with the valve at the 12 O'clock positiontill the beads pop into place .... this has always worked for me
you will most probably see some of the sealant leaking on the sides near the valve
Trek Emonda SL6
Miyata One Thousand
Miyata One Thousand
anyone mounted this one yet?
I will order clincher corsas graphene 2.0 today
I did 85km on my tubeless Corsa's today.
Mounted first time on Enve rims. Added 30ml of sealant and ran at 90 rear, 85 front (I'm 85kg).
They are SO plush and grip like mad. Don't feel as fast as GP5Ks and quite noisy in comparison, but love them.
25c was 283 and 287g.
Let us know how puncture proof these tyres are for you. With Kristoff’s experience (3 punctures) during Paris Roubaix i’m interested in how well they survive normal road surfaces as i’m considering them.
Have about 400 miles on 25c corsa 2.0s. Zero complaints, zero punctures. They ride like a pillow and grip like an aired down Hoosier on a prepped track. Seem to be the fastest tire I’ve run and equal or better riding than anything. This is the only tire I’ve been able to 100% trust.
I'm really intrigued to see how they compare against the GP5Ks in RR.
Must agree that they stick to the road like mad. Quite a noisy tyre though!
Apparently the new corsa tubeless have been used by a few pro teams the last few months to lots of success. Apparently very low crr, and very good handling.
Is this just by checking the result sheets or you heard teams talking about it?RocketRacing wrote:Apparently the new corsa tubeless have been used by a few pro teams the last few months to lots of success. Apparently very low crr, and very good handling.
All the Corsa 2.0s besides a couple bikes like Kristoff's I've seen have had nude/tan sidewalls and thus can't be tubeless. The tubeless Corsas ONLY come in black.
I want to by the new Corsa 2.0, but how do i know it's the newer version (2.0) not the previous 'corsa'?....
For example, which version is this: https://www.vaneycksport.com/nl/fietson ... -25mm.html
That's the old version. New one is predominantly marketed as Corsa Graphene 2.0.
They look like this (these are obviously the TLR version):
- Contact:
Those are the old ones... The new ones will be labeled as 2.0 and will be full price.ducman wrote: ↑Wed Apr 17, 2019 11:46 amI want to by the new Corsa 2.0, but how do i know it's the newer version (2.0) not the previous 'corsa'?....
- Contact:
I have been a steady user of the original Corsa G+ tires for the last two years on my road bike and the Corsa Speed tires on my TT bike. I know that some people have complained about the durability of the originals, but in my experience these tires do remarkably well for what is essentially a race tire, and I've put thousands of miles on mine. I can't say I haven't had flats or punctures, I have.... but its always been when I was pushing the tires well into their worn phase and riding in sh*t I shouldn't have been riding in.
I have a set of the 2.0's coming and I'm looking forward to seeing how they fare.
