Vittoria Graphene 2.0
Hexsense
by Hexsense
alanyu wrote:
Sat Jun 08, 2019 9:07 pm
Valy wrote:
Sat Jun 08, 2019 7:04 pm
alanyu wrote: The limit of Pro one 25c/28c is only 70kg/75kg on their website, which I think a lot of people don't take care of.
Would not that be per wheel? Image
:o TYTT I don't know whether it's for pair or per. :oops: I hope it's for per wheel.
Per wheel, but weight distribution of road bike is like F/R 40/60. So rear 75 kg would translate to front 50.
Still, it sum to 125kg total weight which should be plenty.
by Nefarious86
Mr.Gib wrote:
Nefarious86 wrote:
Sat Jun 08, 2019 8:28 pm
willmac wrote:Is that really the same tire? Looks like grey sidewalls, not tan
Alloy brake schmutz
Sent from my SM-G975F using Tapatalk
Oh yeah that's the same tire, and it has been wiped several times. I went through a set of brake pads in three days. The guys on disc went through pads in two days. Descending so steep, wet, rough, and technical you could never let the bike go. Horrendous roads, always wet, often raining and mud, sand, grime, pureed plant debris, and indeed alloy "schmutz" - well put Nefarious.
How much was chewed out of the rims?
As for the disc guys, they should have been on metalics lol.
Using Tapatalk
RocketRacing
by RocketRacing
spdntrxi wrote:
Fri Jun 07, 2019 3:14 pm
emcardle wrote:
Fri Jun 07, 2019 1:50 pm
Corsa Speed 2.0 is faster
https://www.bicyclerollingresistance.co ... a-speed-g2
can we beg for a 28mm version :thumbup:
Would prefer to see crr of the 23c 2.0 corsa speed. The 25c was measuring 27mm... which could account for much of the crr improvements over the 23c originals.
TobinHatesYou
by TobinHatesYou
RocketRacing wrote:
Sun Jun 09, 2019 9:24 pm
The GP5K comparison suggests differently. The 23mm and 25mm GP5Ks were within 0.2W down to 80psi. I imagine it would be more like a 0.1W difference in the Corsa Speeds.
Besides, 25mm is the "baseline" on BRR. 23mm Corsa Speed was only tested because the 25mm version didn't exist at the time.
JScycle
by JScycle
Hexsense wrote:
Sun Jun 09, 2019 7:54 am
If the weight limit of the tyre is 75kg per tyre than that is heaps. If you are 100kg and have a 40(F)/60(R) weight distribution then the front has 40kg of load and the rear has 60kg. You could be 125kg before you hit the load limit on the rear tyre (not accounting for weight of clothing etc)
Stitchking
by Stitchking
Just to update my previous post about my rear rubino losing air. Pulled the tyre off and my rim strip looked like this:
Have retaped with stans tape and have had no more loss than should be expected. Not a tyre issue which is nice.
Sent from my SM-G935F using Tapatalk
ryanw
by ryanw
That an Enve rim / tape?
My 5.6s were taped so so bad from factory! I was losing a fair bit of air. When investigating, rim tape was poorly installed and the rear had a tear in it.
Removed and installed Tesa 25mm tape and been perfect since.
'16 Cervelo S5 - 6,650g RIP
'17 Focus Mares Force 1 - 7,170g
'19 Cervelo S5 Disc - 7,460g
IG: RhinosWorkshop - Check it out for all my custom builds :thumbup:
:!: Ride Southern Spain Cycling Holidays *£445 for 7 Nights* :!:
Stitchking
by Stitchking
ryanw wrote:That an Enve rim / tape?
I wish hahaha. Its a giant slr wheel
TobinHatesYou
by TobinHatesYou
Looks like the tape doesn’t cover the entirety of the rim bed in that photo. Not sure if they biased the first layer on one side and then the second layer on the other sides but I’m a big proponent of going with tape about 5mm wider than the internal rim width and letting it ride up the sides of the rim slightly.
ryanw
by ryanw
Agree. Also, I compress the tape into the channel which eats up a few mm width.
21mm was too narrow for 5.6s, 25mm was spot on.
Stitchking
by Stitchking
The tape i replaced it with was 21mm stans from memory. The rim is quite narrow at 17c so seemed to give a good coverage. Definitely filled the whole rim bed adequately.
Mr.Gib
by Mr.Gib
Nefarious86 wrote:
Sun Jun 09, 2019 7:05 pm
Alloy brake schmutz
The rims definitely saw some wear but not terrible. I was using Jagwire Elite/Pro whatever pads. They are pretty firm. A softer pad would have sacrificed itself and saved the rim a bit more, but would have been destroyed even faster. Had the same thought about the guys on disc. The whole trip was the ultimate torture test for equipment. Basically like riding a combination of a mountain tour stage and a cobbled classic in the rain for ten days in a row. Off topic for this thread but I'd think long and hard before I'd bring electronic shifting on any trip like this. Lots of serious problems for the guys on electonic. Zero mechanical drive train issues. The group of 20 was split evenly between electronic and mechanical.
Calnago
by Calnago
Mr. Gib... I don’t know what trip you were just on, but I would like to read a more detailed writeup of it, maybe in a thread if it’s own, if you have the time. I know in conditions like that, picture taking often isn’t a priority but if you’ve got some, that would be great too. Sounds like an ordeal.
refthimos
by refthimos
ryanw wrote:
Mon Jun 10, 2019 9:57 am
I strongly recommend using only Enve tape for Enve wheels. Not because other tapes aren't as good, but because Enve may not warranty your wheel if you use another tape and air escapes from the rim edge of the rim bed into the side of the rim and blows it apart... happened to me.
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8/FFWD Falcon | Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
Mr.Gib
by Mr.Gib
Calnago wrote:
Mon Jun 10, 2019 4:12 pm
Yes, stopping was definitely not a priority. In the crazy places stopping meant some of those I was with might not have been able to get going again, and every moment wasted increased the likelihood of a last descent of the day in pitch black. Very few photos exist and the catch is that they include other private individuals. But fair enough, I owe the good people here a few photos. Watch the on the road thread. I'll post a couple to show road surface without comment. Sadly no photos could be taken when it was raining hard with was most of the time and it was raining hard when the most photo worthy madness was ridden.
