Remove Dura Ace decals on 9100 brakes
PinaRene
by PinaRene
Does anyone know if it is possible to remove the Dura Ace 9100 decals of the brake calipers, and has anyone tried it ? Polishing or Acetone might work I guess, but with it leave some marks behind ? I want to give the 9100 brake calipers a chance on my eTap bike to see if I can get a better caliper set-up.
Lewn777
by Lewn777
I think they are sprayed on under clear-coat, so I doubt acetone will work, it would probably be a case of light sanding and re clear-coating, but I doubt you'll end up with such a nice finish. BTW I've got 9100 Dura Ace calipers and they look great and work extremely well on my SRAM Force 22 mechanical bike. personally I don't care about having a mismatched groupo and have no need to remove the decals.
ilikegreen
by ilikegreen
Put some black electrical tape over it while you're testing. Pretend it's a prototype component.
TonyM
by TonyM
ilikegreen wrote:Put some black electrical tape over it while you're testing.
That‘s what I do on some parts on my bikes.
Easy method (also used by some Pros).
