Scott Foil Disc BB
Papey
by Papey
Hey,
Found a decent deal for a scott foil 10 disc, but curious what BB compatability i'd have to put a powermeter/cranks on. It's a Shimano SM-BB71-41B - does this mean I'd have to replace it for a BB86 to fit a spider powermeter?
Omiar
by Omiar
Shimano SM-BB71-41B bottom bracket is a Pressfit BB86 type bottom bracket.
Type: Pressfit BB86
Shell Diameter: 41 mm
Shell Width: 86.5 mm
Axle Diameter: 24 mm
Scott Foil Disc Ultegra Di2 R8070
Scott Foil Ultegra Di2 6750
Scott Scale 935 carbon 2015 Di2 - the "gravel eater / winter bike"
Scott Spark LTD 29" XT M8000 - sold
Scott Scale 35 26" - sold
Karvalo
by Karvalo
Papey wrote:
Sat Mar 09, 2019 10:09 am
No, because (as said above) it is already BB86, but really you're asking the wrong question because BB86 refers to the frame standard, not the crank type. If the powermeter you're looking at uses a Shimano style straight 24mm axle it'll go straight in. However, if the type of powermeter you want to fit is different (for instance Quarq GXP or 30mm) you would need to change the BB to fit the spindle.
