What’s your favorite saddle?
sfo423
by sfo423
TobinHatesYou wrote:
Tue Jul 16, 2019 7:55 am
Just guessing, but his method was likely going to a fitter who then measured with a goniometer.
Can you explain me your method to mesure your flexion ?
Went to a fitter last year and that was one of many variables. I believe +55 to +65 is the range of 'normality.'
wheelsONfire
by wheelsONfire
Speedman wrote:
Tue Jul 16, 2019 7:34 am
sfo423 wrote:
Mon Jul 15, 2019 10:46 pm
I have a lot of drop as you do (~10cm). Did you run your Arione flat or nose tilted down?
My max hip flexion is pretty good; recently measured at 62d and a trunk tilt at 43d. Sounds like from a textbook perspective a Dimension may be a good candidate.
I would like to know this to
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Speedman
by Speedman
sfo423 wrote:
Tue Jul 16, 2019 2:57 pm
Do you know if the famous fitters (like Bikefitting, Retul, Gebiomized...) can make this kind of mesurement ?
I have already try the Shimano bikefitting system and the checking of the flexion was not in the variables system. But It interested me particularly because I make an hard work with a physiotherapist to improve my flexion.
sfo423
by sfo423
I used an old school fitter that also uses the new age tools to dial in fit. I think he uses BikeFit. They attach reflective stickers to certain body parts and measure using strobes & software or something.
I would not use a fitter than soley relies on tech to fit. Get someone that knows how to fit.
Speedman wrote:
Tue Jul 16, 2019 3:20 pm
bikeboy1tr
by bikeboy1tr
I have SMP saddles on two road bikes, one is the Composit and the other is the Full Carbon and even though they are from the same family they do differ somewhat in the position that you sit. Out of laziness I made the mistake of assuming the seatnose behind the BB would put you close to the same position from one to the other. Today I actually took the time to measure out with plumb bob, short level attached to my shoe and marking the cranks for horizontal position visible from the sitting position. I am trying to duplicate my position from an older Time to my new Colnago and discovered that even though the two seats are a bit different the graduations on the seat rail from the Composit to the Full Carbon will put you in the same seating position (knee over pedal) but the nose will Not be at the same distance behind the BB.
The reason I am going through all this is because I have been getting some pain at the base of my neck and I know its from my seat position, but because I had originally measured out from seatnose behind BB it put my sitting position further behind the BB with the Composit than the Full Carbon.
Lesson learned, dont be lazy like me.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
bikeboy1tr
by bikeboy1tr
So I was getting tired of waxing my black leather SMP Composit and decided to remove the cover after I checked out the website which shows the seat shell as being black. I grabbed a small box cutter knife and sliced a small incision along the back side of the shell to get a look at the colour of my shell and sure enough its not black but dark brown. I decided I could live with that and proceeded to remove it anyway. I got out for a hour and a half ride to see how different it would be and was happy with the outcome. I can easily get in and out of the saddle without shorts hanging up and when I sit down there is no distortion of my shorts if I dont hit the saddle square. Its a nice friction free surface just like the Full Carbon but a nicer shell design as far as I am concerned. Maybe now my shorts will last longer as no more accelerated wearing around the thigh area. No regrets well maybe not the most desirable colour but I am good with it.
InDustWeTrust
by InDustWeTrust
Fizik Antares, or Fizik Aliante. Flite titanium leather for commuter or mtb or if you want a saddle that lasts.
TheRich
by TheRich
InDustWeTrust wrote:
Wed Oct 30, 2019 11:14 pm
I put an old (probably 15 years old) but lightly used Flite on my road/gravel bike and it was every bit as great as I remembered it.
Truly legendary saddle.
hanakuso1
by hanakuso1
I've recently bought a Brooks C17 Carved. It's only 4mm wider compared to my previous C13 Carved in 158mm, but the frame is slightly different. It fits me better and I think i'll keep this on my bike for now.
But it weighs 446 grams.....
Slightly related but the C13 Carved in 132mm is on sale for $94. Basically the price of the steel rail version but it's carbon fiber. Seems like a great deal if you want a narrow saddle.
https://www.amazon.com/Brooks-England-C ... 221&sr=8-1
