Let's talk rotors
skyliner1004
by skyliner1004
My bike came stock with DA hydrolic disc's 160/140.l centerp9ck rotors. Is it possible to change the rear to 160mm also? Is it simply a "unscrew the 140, screw in the 160?"
Also vice versa, if one wanted to change the front 160 and buy a lightweight 140 or an OEM DA 140 rotor, would it fit?
2018 Supersix Evo Hi-Mod Disc Dura-Ace
Conti SS + Gp5000
3t Ernova Team
Garmin 520 Plus
Look Keo Blade 2 Carbon Ti
15lb 15oz
ryanw
by ryanw
skyliner1004 wrote:
Thu Jul 18, 2019 3:08 pm
You would need to add an adapter / mount to change from 140 to 160, front or back. If it already has an adapter, sometimes you can just flip it to accommodate the larger / smaller rotor.
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
LiquidCooled
by LiquidCooled
Most likely, you have an adapter on the front already. It’d be set to 160, so you could flip it to the 140 setting. The rear likely does not have an adapter, so you’ll have to buy one to use 160 in the rear.
I’d keep the 160 on the front if I were going to use a 160 and 140 combo. My bike came with 140s front and rear. I changed both to 160.
Edit: To be clear, with flat mount brakes, typically, the front always uses an adapter. The front adapter has a 140 position and a 160 position. Depending on which you want, you orient the adapter accordingly. On the rear—again typically—there is no adapter necessary for 140. For 160, you have to use an adapter. The front and rear adapters are obviously not the same.
2017 Giant TCR Advanced Pro 0 Disc
2003 Cannondale R1000 (CAAD7)
angman19
by angman19
I use SRAM etap right now and brakes have too many issues with noise. Possible to use the XTR rotors with my sram system?
angman19
by angman19
wheelsONfire
by wheelsONfire
Drag or squeal, bad retraction of pistons or uneven rotors?
I heard some whine about rotor drag in the front while sprinting?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
jlok
by jlok
angman19 wrote:
Wed Sep 02, 2020 5:52 am
I'm using the XT rotor with old monoblock and new two-piece calipers, and guess XTR would be working fine the same.
TobinHatesYou
by TobinHatesYou
Details?
Whatever issue you have with the SRAM rotors, I doubt will be solved with Shimano rotors.
eljamoquio
by eljamoquio
Karvalo wrote:
Fri Mar 08, 2019 8:53 am
And yet I've never seen a road bike with 203mm rotors :wink:
Admittedly not 203mm, but my road bike *does* have 622mm rotors.
edchristoph
by edchristoph
ryanw wrote:
Wed Apr 10, 2019 11:35 am
I think they look better than the DA 9100 rotors, and they weigh 22g less combined (160/140mm):
I was using that exact combo for quite some time and while they look better and weigh less than the the DA rotors, I was neither happy with the aesthetics nor the performance after all.
When it comes to aesthetics nothing comes really close to the Campy rotors IMHO.
I was very tempted to give them a try, but the discussion around here (viewtopic.php?f=3&t=145230&hilit=campag ... 0#p1521713) concluded that the don't mate well with DA calippers which kept me from doing so.
After watching a GCN tube on André Greipel's new Factor One bike from ISN team (https://www.youtube.com/watch?v=3Jcg2eHeppk&t=253s) I was quite attracted by the look of the Swissstop Catalyst discs which the team is using in combination with DA groupset. And if they are good enough for André they will be good enough for me...
I currently use them in 140/160 size in combination with the Swissstop 34 RS pads. I like the look much more than the XTR rotors and I am very happy with the performance, too. Good braking power and modulation, very silent (no squealing or similar Chewbacca sounds) and no disc rub ("ting,ting") after hard breaks or when out of the saddle.
The only downside is that they are not exactly lightweight at 122g/160mm and 110g/140mm. I am looking into the new Galfer rotors (viewtopic.php?f=3&t=145230&hilit=campag ... 5#p1585225) which are ridiculously light but I am not sure if I like the looks of them. That wavy edge seems more appealing to MTB application rather than on a road bike.
NordicSal
by NordicSal
edchristoph wrote:
Thu Sep 03, 2020 9:55 am
Is this an XL size Endurace or Ultimate? I really want my Endurace to look like that, need a summer wheelset and a cockpit
edchristoph
by edchristoph
It's an Ultimate in size XL. I am 195cm tall...
rides4beer
by rides4beer
I still like RT81s for aesthetics, clean and simple design, and I haven't had any issues with their performance (I'm 185lbs and have done over 500k ft so far this year).
NordicSal
by NordicSal
edchristoph wrote:
Thu Sep 03, 2020 4:21 pm
Nice, looks a lot like my Endurace, same size. I am around your height, a bit taller but less than 2 metres. Endurace and Ultimate look really nice even in the XL size, that's not often imo.
Hexsense
by Hexsense
eljamoquio wrote:
Wed Sep 02, 2020 8:29 pm
Let me guess: a terribly hollow non-steel 622 rotor that can't withstand hydraulic pressure. And it does not run true enough to have less than 1mm gap between the pad and rotor (thus need more clearance but less leverage caliper)?
