Deda HSS spacers
Courie90
by Courie90
Hello there
i bought a new bike, a giant tcr disc. I would like to chance the spacers on the bike, because of the oversized steerer tube the spacers are not so wide at the outher diameter ( it does not have a clean fit to the stem). afters searching the web i found the deda HSS spacers, this seems to be a solution for this problem. any one used them ?
also they come in 2 diamaters, 46m and 49.8 mm, wich one should i need for the giant ? i guess the 49.8mm version
thanks
grtz
Angelo
hannawald
by hannawald
I think it is not compatible with Giant. 46 or 49.8mm is the outer diameter of spacers depending on what your head tube looks like. What is a problem for you is inner diameter as Giant, Canyon and Scott Foil use fork with larger diameter steerer so inner diameter of spacers won't fit. It may be easy to cut inner ribs in spacers but with headset cover it will be a bigger problem..
