Bura SL Seat Clamp/Wedge
rugbymad76
by rugbymad76
Hi all
Bit of assistance and advice needed on sourcing a replacement or alternative seat clamp/wedge for a Neil Pryde Bura SL 2017 frame.
Im needing to replace my missing part.
I believe Neil Prdye are no longer around unless im wrong? Does anyone know if any alternative brand spares could fit?
Thanks
AndreLM
by AndreLM
You need a 30.7mm clamp. I got this one from KCNC... Works great.
https://fairwheelbikes.com/kcnc-sc9-seatpost-collar/
Enviado de meu SM-G950F usando o Tapatalk
darnellrm
by darnellrm
You actually need a 30.0 clamp. The normal 30.7-30.8 will probably not work.
I have 2 Bura SL's..... FWIW
AndreLM
by AndreLM
KCNC SC9 30.7 in my 2013 BuraSL. Never had any issues since I mounted it back in 2014.Image
Tenlegs
by Tenlegs
2017 Bura clamp/wedge
rugbymad76
by rugbymad76
Cheers for the info guys.
AndreLM and darnellrm, thanks for the suggestions much appreciated. Would I be right in assuming you both have an earlier model than mine with a "traditional" seatpost clamp rather than the wedge on the 2017 frame?
Tenlegs, thanks for uploading the photo, guess i could have thought of that :) and saved confusion over clamp/wedge. This is the same model as mine for ref.
Anyone any further info/advise on replacment or altertatives which could fit?
Thanks
AndreLM
by AndreLM
Yep... Mine is a previous version... Didn't know they changed to an internal wedge type.
And it really looks like the brand is now gone. It might get difficult to source an original replacement.
One thing you could try is contact Chapter 2 Bikes and ask them if the expander for any of their current bikes is similar (Mike Pryde was the bike designer at NP before starting C2)
