D/A 9000 hub conversion
kgibbo1868
by kgibbo1868
Can anyone tell me if I can convert my DA 9000 hub from Shimano to Campagnolo? I am thinking of going record 12 speed on my next build.
2019 Baum Ristretto
Pain is my friend!
mattr
by mattr
No
kgibbo1868
by kgibbo1868
Sad..... :-(
Thanks for the reply!
2019 Baum Ristretto
Pain is my friend!
pdlpsher1
by pdlpsher1
Some hubs do allow you to switch between the two style freehubs readily. For example, if you buy a set of Campy or Fulcrum wheels (both made in the same factory) you can switch between the Shimano or Campy freehubs. I believe DT Swiss is the same way, plus some other I'm sure. But Shimano has never made a Campy freehub to my knowledge.
mattr
by mattr
You'd never get a campag spline to fit over the shimano bearings and axle/freewheel hardware.
