DT Swiss M 1700 vs FFWD Outlaw AM Carbon
Roadrocket
by Roadrocket
Looking for new pair of wheels, ffwd looks like a bargain now: https://www.ffwdshop.com/FFWD-OUTLET?product_id=345 549euro
DT Swiss M1700 30 are wider and heavier 285eur shipped: https://www.dtswiss.com/en/products/whe ... spline-30/
Worth to pay more for carbon FFWDs or get proven DTs?
Not so many reviews of Outlaws there.
Thanks
de lars cuevas
by de lars cuevas
Hi There,
the FFWD seems like a steal! Questions:
Is the 33 mm rim width of the FFWD inernal or external?
What tire width do you intend to use?
What's your intended use for the wheels?
Roadrocket
by Roadrocket
Hi,
I am pretty sure 33mm is external and internal width is just 26mm. There is 7mm difference between int-ext dimesnions, but it´s probably because carbon needs thicker walls than aluminium.
I´m using mostly 2.3-2.4 Maxxis tires.
Intended use all mountain to enduro.
de lars cuevas
by de lars cuevas
Considering you run wide tires, and intend to push them hard, the FFWD might be a little on the narrow side.
Roadrocket
by Roadrocket
You´re probably right. Anyway I just ordered a pair of 30mm DT M1700(285eur shipped is bargain too) and will consider that FFWDs further, maybe they will lower the price in outlet yet.
Zachariah
by Zachariah
My DT Swiss M1700 i25 wheelset weighed 1784g. I replaced the stock Easton ARC30:
Due to the urging of all the ladies...I do NOT shave my legs!
