Changing the angle of sram tt shifter paddles
jobvisser
by jobvisser
Is there a way to change the angle of the shifter paddle your sram mechanical rear tt shifter?
I want to race timetrials under uci regulations this summer and therefore my shifter has to be within 10 cm of my elbow pad in terms of height.
on the front (left) shitfer you can just turn it by 30 degree increments which allows for a perfectly flat lever on pretty much every handlebar .
On the rear shifter (right) this is not possible and i would like to know if there is a way to still turn the lever forwards/down a bit so i can keep my elbow pads low.
There still is about 90 degrees left when the lever is in the lowest position, so maybe it's possible to turn the internals within the paddle. Another way to reduce the height of the shifter is just installing it upside down but this means cabling will be a mess. a
Has anyone got any advice/suggestions ?
 this is the rear shifter in the easiest gear
and this is the rear shifter in the hardest gear.
mattr
by mattr
Are you using all the bar?
You could chop a couple of cm off the end to gain some height, you'll get the same grip "area" but some of it will be shifter.
Or get the RTC shifters.
kman
by kman
AFAIK, you can't do anything about it. The R2C shifters will solve your problem but are very expensive.
I've disassembled both types (and painfully rebuilt the "non-user serviceable, send them back to SRAM" R2C shifters) and I don't rmember any type of angle adjustment in the standard shifters.
You can't be a real country unless you have a beer and an airline. It helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer.
-- Frank Zappa
