Smallest hand pump
survivor
by survivor
Hi, does anyone know what would be the smallest hand pump available on the market today?
kode54
by kode54
Most of the small pumps don't work that well...at least the ones I have tried. I've been eyeing the Silca pump.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
Sizzler
by Sizzler
I have a Blackburn Airstik 2 stage pump. It's small, light and good for emergency use.
TobinHatesYou
by TobinHatesYou
kode54 wrote:
Fri Feb 22, 2019 10:48 pm
The Pocket Impero is not that small and VERY heavy. It’s a nice pump, but mini-pumps are something I’ll use a low single-digit number of times a year. For me that means getting the smallest, lightest pump that doesn’t outright suck. I settled on the Topeak Micro Rocket...it gets my tires back up to rideable pressures. The only thing it’s missing is Schrader compatibility if some random person on a BSO asks for help.
PokojniToza
by PokojniToza
I have Topeac's carbon micro rocket.
https://www.topeak.com/global/en/produc ... ket-carbon
its about 15 cm long and weighs about 55 g.
uraqt
by uraqt
I have the carbon micro rocket and it's work great for about 5 or 6 years, maybe longer... but I might get 3 or 4 flats every 3,000 or 4,000 miles...
C
I have a Pocket Impero but haven't figured out how to carry it.. all my pockets are full when riding...
I have noticed that the metal pump face has scratched my training rims but I think any pump with a metal pump face will do that...
mikemelbrooks
by mikemelbrooks
survivor wrote:
Fri Feb 22, 2019 10:34 pm
https://www.planetx.co.uk/i/q/TOBANO/ba ... 00psi-pump
The Nano is a top-end, high-performance Road pump that is capable of inflating tires at up to 100 psi
It has been made from Titanium with a Carbon Fibre look to ensure exceptional reliability, performance and extremely low weight
This pump is fully compatible with Presta and Regina valves
Weights only 39 grams!!
RocketRacing
by RocketRacing
I have an ipump (i think that is it). Pretty small and only 21g. And it works! Just don’t expect high pressures, despite the claims... unless you are a gorilla.
Geoff
by Geoff
I have one of the Topeak Micro Rocket, as well. I once conducted a long-term clincher test and had quite a few flats, so I actually used it. It was surprisingly good and you could actually get pressures up reasonably high (rideable, anyway) without too much effort. Since being back on tubulars and starting a long-term tubeless test, I haven't had to use it at all. For peace-of-mind, though, it is pretty good, since I know it will work if I need it.
Valbrona
by Valbrona
Airace Road Torch is 12cm - 4cm smaller than the Topeak one mentioned above.
Airace Torch comes in three types - MTB, Road and Bisexual versions.
Stendhal
by Stendhal
I have a compact Bike Tube Brand ( new name for their web site, it’s good ) pump that is 6.25 inches and pretty good in a pinch for a flat while riding.
Specialized used to have a pump just smaller than that, I had 2. Not quite as good, but very compact. :thumbup:
Cervelo Aspero (7.75); Orbea Orca OMX (7.30)
Retired: S-Works Tarmac SL6, LOW// mki, Pinarello Dogma F10\F8, Lapierre Pulsium, TIME Fluidity, Wilier Cento1 SR, Ridley Noah, Cyfac Cadence, Cervelo S2\R3\R5, Felt Z25, Klein Quantum, Cannondale 2.0
flying
by flying
Don't know what is considered small but...I use the ProBike Tools pump
Small enough it easily fits in a jersey pocket & does not stick out
Works well & gets my 700x25 up to pressure after a flat
Nice quality & price as is all their stuff IMO :thumbup:
TonyM
by TonyM
I have many but the Blackburn Airstick SL is my favorite! Light, small and it works.
Js2
by Js2
PokojniToza wrote:
Fri Feb 22, 2019 11:48 pm
:up: second this, been very reliable in a very small package! Going strong in its year 2 of use now.
maxxevv
by maxxevv
That is the slightly improved version. I have had mine for about 10 years now !
Pretty good if you want to get it up to rideable (limp home) pressure. I can get it to the 80+ psi range out on the road, though it will take a lot, as in A LOT of pumps.
I checked with my floor pump after getting home once. Air would only go in when the floorpump meter read somewhere between 80 ~ 90 psi.
