SRAM Etap playing with Etap AXS
solarider
by solarider
Has anybody tried to mate Etap Gen 1 shifters to a Gen 2 AXS mech?
Appreciate you might lose the ability to use the app, but I have a perfectly decent set of levers and disc brake calipers and I just can't justify new shifters and brakes (that are identical to the Gen 1 version BTW).
With rim brakes, at least you had the ability to just change levers and keep your existing calipers. For the moment at least SRAM aren't giving you that option and you have to buy a set of brakes you don't need. Coupled with them pushing a full groupset on you and launching a disposable power meter, the new group isn't a great exercise in sustainability!
In theory the brain is in the mech and the levers just send a signal to move 'up' or 'down'. They say officially that there is no backwards compatibility, but I just wondered if anybody with access to both has been able to verify that? Do you work in a bike shop with bikes on the shopfloor with both fitted that you could work side by side? Are you one of the lucky few to actually have a set of your own?
Karvalo
by Karvalo
solarider wrote:
Thu Feb 21, 2019 8:44 am
Right, but they send the signal in a different language. It's like the lever is saying 'Up' but the mech needs to hear 'Arriba', y'know?
by Nefarious86
Not compatible in any way shape or form.
Using Tapatalk
izza
by izza
I’m looking to upgrade to AXS.
They have done a good job in stopping people save money by mixing and matching.
1. Different protocol so you can’t use old levers
2. If you could use 11 speed chainrings with 12 speed chain, the difference in front rings is 13. Only way of using old Quarq and FD set up is 52 and 39 but they have different BCD.
Presumably if you wait someone like Absolute Black will come to the rescue of older Quarq meters. Or use Shimano.
3. New cassettes need new hub body.
Looks like I’ve got a lot of Etap to sell.
The only bits that are compatible .... the batteries. The bits SRAM have been the most problematic. Go figure.
gurk700
by gurk700
izza wrote:
Thu Feb 21, 2019 11:05 am
More old etap for me. I'll buy your old etap for dirt cheap :) :beerchug:
bikeboy1tr
by bikeboy1tr
You can likely get away with using 11sp rings with the 12sp chain as the worst that can happen is the chain drops inbetween the two rings when you shift from big to small which is no biggie as you just shift the rear one way or other and reshift front if it doesnt pick up on its own. I have in the past used 11sp chain on my 10sp rings with no issues. When I was doing it with the 10sp chain on the 9sp rings it was dropping the chain inbetween when I was in the middle of the block on the rear.
If you have used Absolute Black rings together you will see that they have a condiderable gap between the two and they are compatible with 9,10 and 11sp setup. At least that is how they mount up on my DA9000. I was getting chain drop inbetween frequently which not a big deal but then I found that mixing a Rotor inner with Absolute Black outer decreased the gap enough to eliminate the issue.
viewtopic.php?f=10&t=154188
2018 Colnago V2R Rim Brake
2012 Time RXRS Ulteam Rim Brake
2008 Time VXR Rim Brake
izza
by izza
Haven’t checked the full Absolute black range but getting the 13 teeth difference and BCD is the issue. The depth of the FD is the big limit not the width.
RussellS
by RussellS
But, is the lever saying "UP" one or two or three gears. And "DOWN" one or two or three gears. Or like with mechanical is it saying "UP 3.85 mm" and "DOWN 3.85 mm" with 11 speed. And "UP 3.43 mm" and "DOWN 3.43 mm" with 12 speed. Just making up the mm numbers. With mechanical the AMOUNT of up and down is controlled by the lever. The derailleur does not control the amount of movement. That is controlled by how far apart the clicks in the lever are. It MIGHT be the same with electronic shifters too. The lever determines how many millimeters the derailleur moves up or down. The derailleur just moves in an arc. The derailleur does not control how far it moves except by the limit screws. So an 11 speed shifter will tell the 12 speed derailleur to move too far on every shift. Even if they speak the same language, as pointed out by another that may not be the case.
robertbb
by robertbb
Back in the day (circa 2000 - 2006) I was involved pretty heavily in the open source movement with various projects (GNU/Linux, Gnome, OpenOffice).
The (very smart) people involved in those projects saw the writing on the wall through the MS antitrust years. I remember Richard Stallman telling me that since the dawn of time, publishers have been looking for ways to charge every single person that reads a book. Or even charging the original purchaser each time they read it...
This was before Kindle...
When companies can:
- Lock people into file formats only their own software can work with
- Charge a subscription model for ongoing access, support and/or compatibility
- Discourage users from leaving the "ecosystem"
The consumer gets boned.
Not long before the bike industry goes this way.
I get that prior to 11 speed, we were pretty much stuck with whatever "vendor" we had chosen. But 11 speed brought unprecedented compatibility and this is a good thing.
That time is now over.
Wait until they start embedding chips/sensors in sprockets, chains, cranks/rings... and expect to be unable to tweak, tune or mix-n-match. Wait to be charged for "premium" shift experience... or simply for support. Only "authorised shops" will have the tools and electronic interfaces to support your equipment. Look what happned with the automotive industry. Already there was a power meter (forget which one) that went out with fully functional hardware but which required a further digital purchase to "unlock" extra features.
Might seem far fetched but these days, no industry is immune.
mattyNor
by mattyNor
You can't use 11s rings with 12s Sram unfortunately apparently they slightly increased the size of the roller links in the chain. After trying to set up a Thm crank with Absolute Black rings and 12s axs group it just doesn't work. The chain catches on the rings because it's just slightly too big to mesh properly. People like to call Shimano evil but Sram have really locked you into the whole system with this generation.
Sent from my Pixel 2 using Tapatalk
tabl10s
by tabl10s
Nefarious86 wrote:
Thu Feb 21, 2019 10:36 am
Can you use the FD/RD with an 11sp set up(including chain)? Don't care about 12sp, but I want the connectivity.
2015 Pinarello F8: 13.05lbs/5.915kg
2016 Rca: 11.07lbs/5.048kg
2018 Rca
2018 S-Works SL6 Ultralight: 12.03lbs
izza
by izza
FD - Yes. It’s my understanding that the later 11sp Etap FD’s already has the 12sp motor in it. That came to me indirectly from a SRAM insider. Even if Chinese whispers then for cost saving I can see it makes sense from manufacturing cost perspective.
RD - just like mechanical it probably won’t work as spacing is different between cogs.
tabl10s
by tabl10s
izza wrote:
Sun Feb 24, 2019 12:28 am
Is there a way to tell what batch of FD's have the upgrade?
2018 Rca
by Nefarious86
It may have the same motor but the communication protocol is completely different. The 12s shifters and mechs will not mix and match with 11s components.
Why is this so hard for people to understand? They have made 12s it's own ecosystem, the chains chainrings casettes are all incompatible with 11s gear, the stepper motor and programming in the rear mech sets the shifting so the 11 wont do 12 and the 12 wont do 11 and the front mech wont talk to the different series mech new to old or old to new, there is no mixing and matching except with other AXS specific products in terms of communication and the road chain/cassete wont work with the eagle chain/casette and vise versa due to roller diameters etc.
Using Tapatalk
izza
by izza
Not that I know. The casing is the same. However, there are threads on here and other forums of chain dropping. I’ve experienced the same and found later FD’s need to be set up so precisely when early versions were much easier.
Whether you can get a 12sp set up to work on the 11 with limit screw position and RD position would surprise me since the movement (equiv. of mechanical pull ratio) is slightly different.
