Orbea Orca 2020
bilwit
by bilwit
wheelsONfire wrote:
Thu Sep 05, 2019 10:56 pm
Why does all these "new bikes" look so similar... It's boring!
To their credit it looks like there's enough there to set it apart from just another dropped stay semi aero bike, at least moreso than Scott, Cannondale, etc. I love the bowed out fork and the paint customization is a huge plus. Same classy appeal of the old OMR but with sone modern touches
g32ecs
by g32ecs
Hexsense wrote:
Thu Sep 05, 2019 8:49 pm
Found the rake on Orbea's website
Fork rake=48mm for size 47-51 and 43mm for size 53-60.
Now we can calculate tail.
size 47 trail=66
size 49 trail=63
Size 51 trail=59
size 53 trail=60
size 55 trail=59
size 57 and 60 trail=58 , Only size 57 and 60 handle as fast as Supersix Evo which has trail=58mm on all sizes..
Overall, except size 47 and 49, they seems to do okay. Almost monotonically faster handling as you go up the size. But certainly not as consistence as the new Supersix Evo or new Cervelo S3, S5.
I dont have the same understanding with geometry as you, but can you explain in more simple terms what you just said about 47 and 49?
Only asking because this tends to be my size with manufacturers. Currently using a Felt AR size 48 and I think it suits me well
https://feltbicycles.com/collections/ar ... 1180517494
I'm in search for an all rounder this time with emphasis on lesser weight, not much so on a more relaxed position
Hexsense
by Hexsense
g32ecs wrote:
Fri Sep 06, 2019 6:59 pm
Sure,
TLDR version: the Orbea size 49 will handle similar to your FELT. But different to most bike of larger sizes.
==== below are extra info about trail ====
the most dominant factor on how fast the bike handle (how easy it is to change direction) is trail value. It is a more dominant factor than wheel base etc. So we want to make sure a bike has trail value in range that make sense. Too low value (fast) and it is twitchy, too high trail value (slow handling) and it is sluggish.
Trail value is a product of head tube angle, fork offset, and wheel height (+ tire height/width).
There are multiple combination that create the same trail value:
for example 73deg head tube angle +44mm fork offset.
or
71.2deg head tube angle + 55mm fork offset.
Both handle (nearly) equally fast because of same trail value=58mm despite the 71.2deg head tube angle +55mm fork offset put front wheel much further away from you (longer wheelbase)
Normal range of trail value for racing road bike is 56-60mm. But small bikes generally got compromised here, because manufacturers slacken head tube angle to push front wheel away but don't create a dedicated fork with more offset to compensate for it (or not enough compensation).
FELT AR3 size 48 use HTA=71deg + fork offset 52mm -> trail=62mm (for tire size 25mm)
this Orbea size 49 trail=63, larger sizes are around 59mm
Specialized Tarmac size 49 trail=63mm , larger sizes are around 58mm
new Cervelo S3 and S5, trail=57mm on all sizes
New Cannondale Supersix Evo trail=58mm on all sizes (except size 44)
In any case mentioned above, those are above standard. They use multiple fork offset to minimize or completely neutralize handling difference across sizes.
Some common notably bad example i can think off are
Giant TCR size XS HTA=71deg+ fork offset=45mm (share fork with all larger sizes) -> trail=70mm while just going up one size to size S and you'll have trail=60mm
BMC Teammachine size 47 trail=76mm
BMC Teammachine size 51 trail=66mm
g32ecs
by g32ecs
Hexsense wrote:
Fri Sep 06, 2019 7:30 pm
Sure,
or
I super appreciate this
I also have a BMC and I find they're sizing a bit too big (TTs always long for all the size ranges). Giant I find the same with their gigantic HTs sometimes (and they rarely offer my size in Canada, oh well)
MMW
by MMW
Judging by cycling tips first ride review, it seems that Orbea didn’t really have aero in mind.
https://cyclingtips.com/2019/09/orbea-o ... n1-killer/
Wired, cause it looks pretty aero.
andreas
by andreas
I think the comment about the TA skewers say it all, changing them from the version with handles to one with plain bolts nets you the same aero benefit as all the aero tubing profiles of the frame itself; (27s per 3600 sec at 50 kph).
It's pretty obvious that other ride qualities matter a lot more.
JayDee81
by JayDee81
What do you think about the base model (M20LTD-D) with the mechanical Ultegra? Will it shift good even with the hidden cables?
xylar
by xylar
The Orca OMX is available in five different builds:
• Orca M20Ltd-D Shimano Ultegra (mechanical) groupset, £4,199
• Orca M20iLtd-D Shimano Ultegra Di2 groupset, £4,999
• Orca M21eLtd-D SRAM Force eTap groupset, £5,299
• Orca M10iLtd-D Shimano Dura-Ace Di2 groupset, £7,899 - 7.5kg
• Orca M11eLtd-D SRAM Red eTap AXS groupset, £8,299
Anyone know if all models use the same frameset? if not how do the frameset weights stack up?
FactoryMatt
by FactoryMatt
saw one in person. looks great.
in between this, parlee rz7, and scott addict RC.
this is the best combo of price and support/part availability (parlees small, uses proprietary bar and stem and doesn't have an aero bar option).
wondering how the ride would be compared to what's likely the more 'exotic' other two options.
any actual weights or ride reports for the medium-to-large sizes?
tarkus
by tarkus
just ordered my omx frameset...now it's time for waiting and refreshing the delivery status every day! :roll:
teebs
by teebs
tarkus wrote:
Tue Nov 12, 2019 4:58 pm
I have a OMX Di2 hopefully arriving within the next 3 weeks - how do you track the delivery status? Thanks
tarkus
by tarkus
teebs wrote:
Tue Nov 12, 2019 5:20 pm
haha good one...just with my account on the webpage. When did you order? Mine is "due" in March :(
But I've heard that Orbea takes its time with frameset-only AND MyO.
teebs
by teebs
tarkus wrote:
Tue Nov 12, 2019 5:59 pm
Ordered at the start of September so it should be 3 months.
Still can't find where to check the order..
tarkus
by tarkus
did you order at your LBS or just online (like I did)?
teebs
by teebs
I think that's the issue, I ordered through my LBS..
