Fulcrum 40T vs Bora Ultra 35
hannawald
by hannawald
Fulcrum 40T vs Bora 35 - is there any difference? Similar construction, braking, hubs and bearings..can 5mm in rim height make any difference? Boras are a bit lighter.. has anybody ridden them both?
hannawald
by hannawald
To rephrase my question - does it matter which wheels i buy - stickers aside? Can i buy those i find cheaper?
Greatestalltime
by Greatestalltime
Good question.
AJS914
by AJS914
hannawald wrote:
Mon Feb 18, 2019 9:52 pm
I can't see why it would matter much either way. Obviously, one wheel is 5mm taller so potentially a few watts faster.
asiantrick
by asiantrick
I own the Fulcrum 40T before I sold it & 3 words to sum it up: Narrow & nothing spectacular
It looks nice and well build though, but I think you can find a better wheelset at that price range. I ended up getting a custom build from NOX.
hannawald
by hannawald
I used to have Boras 35 but wanted to go deeper. I have bought 45mm wheels with even slightly lower weight with dt180 hubs, but miss the acceleration and uphill agility of Boras. I can find Fulcrums cheaper so i was curious if they keep same characteristics as Bora. Another suspision is that the difference was Corsa G+ vs Conti Comp tyres. But i think it was Boras..
AJS914
by AJS914
You probably need to compare the weight of the rims. I don't think a 100 gram difference in hubs will translate into a feeling of uphill agility.
pdlpsher1
by pdlpsher1
The Fulcrum 40T (tubular version) has the CULT bearings. I currently have a set of Bora 35 Ultra as well as a set of the Bora 50 One. The CULT bearings are better than the USB bearings. On the bike stand the CULT bearings spin much longer than the USB bearings. So a fair comparison would be between the Fulcrum 40T and the Bora Ultra. You didn't specify which version of the Bora but I assume you meant the Ultra. The clincher version of the Speed 40 has the cheaper USB bearings. The USB bearings are still a world better than the standard sealed bearings but the CULT is just out of this world in terms of smoothness and low friction.
Mep
by Mep
hannawald wrote:I used to have Boras 35 but wanted to go deeper. I have bought 45mm wheels with even slightly lower weight with dt180 hubs, but miss the acceleration and uphill agility of Boras. I can find Fulcrums cheaper so i was curious if they keep same characteristics as Bora. Another suspision is that the difference was Corsa G+ vs Conti Comp tyres. But i think it was Boras..
Mind if I ask what 45mm wheels or rims you are riding now?
robertbb
by robertbb
pdlpsher1 wrote:
Thu Feb 21, 2019 2:17 am
I agree, and have always believed it's far more worthwhile to upgrade from Bora Ones to Bora Ultras than from Chorus to Super Record.
guyc
by guyc
hannawald wrote:
Wed Feb 20, 2019 7:03 pm
Bora Ultra 50's then....
