New Continental 5000s tires - the CLINCHER (not TL) thread
dricked
by dricked
Mine measured 24.5mm (23) and 26mm (25) on an 18mm internal width rim.
CAAD8FRED
by CAAD8FRED
Can the GP5000TL be used as a clincher, or is it TL only?
Dan112
by Dan112
CAAD8FRED wrote:
Sat May 25, 2019 2:24 am
You can buy the clincher or TL both available
CAAD8FRED
by CAAD8FRED
Dan112 wrote:
Sat May 25, 2019 4:19 am
My LBS put the TL tire on my clincher set-up and said it’s fine. I feel like it isn’t, but can’t find any info online and wanted to prod around.
dim
by dim
CAAD8FRED wrote:
Sat May 25, 2019 4:49 am
I had this discussion with my son a few weeks ago .... he says that you can use tubeless tyres on clincher rims and the only difference is that the tubeless tyres have a stronger sidewall? .... I have not found any info on this though
Trek Emonda SL6
Miyata One Thousand
Jugi
by Jugi
CAAD8FRED wrote: My LBS put the TL tire on my clincher set-up and said it’s fine. I feel like it isn’t, but can’t find any info online and wanted to prod around.
Could you explain your suspicion? Technically, in a tubeless setup pressurized air is trapped via a rubber tire, a carbon or aluminum rim, a valve and possibly rim tape. In a traditional clincher setup, air is trapped in an additional rubber inner tube. Outer tire sits on the rim exactly like when installed tubeless. Sure, you aren't riding the most optimal configuration with a TL tire and an inner tube, but the rolling resistance difference is within single digits per tire. Bigger difference in efficiency results by ducking your head 10cm/4" lower at high speeds.
In my opinion the sidewalls of high performance road tires are relatively sensitive across the whole model range, so wouldn't expect much difference in that regard.
zefs
by zefs
Tubeless tires can be used with tubes on tubeless wheels, but don't use tubeless tires on non-tubeless wheels.
CAAD8FRED
by CAAD8FRED
zefs wrote:
Sat May 25, 2019 8:02 am
Thanks
CAAD8FRED
by CAAD8FRED
Jugi wrote:
Sat May 25, 2019 7:12 am
Some TL tires like Zipp Tangente say Tubeless Only on them
4ibanez
by 4ibanez
I've got about 1,500 miles on mine (23F 25R).
I was initially concerned about longevity - I got a 1cm cut on day 2 on a wet drag. I was chasing a KOM and just went over some medium-ish stones that were in the best line. I was pretty annoyed and wondered how they'd last if you could inflict a cut that early on.
After that incident they seemed almost indestructible to be fair - no cuts for ages. The rear has now softened a bit and I sustained a few small cuts, but it's still a rarity and nothing seems to bed into the tyre. I still ride them without any worry for stones or bad patches of road.
Talking of stones, I have had 1 puncture so far, which was a razorblade of a flint that went in horizontally across the rear tyre a few weeks ago. That may have taken out any tyre to be fair... Other than that they're still holding up fine - and seem to have plenty of life left according to the wear indicators (a nice touch missing from other tyres I've used before).
I haven't found them to be unreliable in rain. Have used them in showers and once on a fast group ride where we got absolutely soaked. There was no slippage whatsoever.
My only other observation is that they're noticably quieter than my outgoing Michelin Pro 4 SC, and the testing does suggest pretty good CRR. I like em so much I decided to buy a 2nd pair - will try a 25/25 as I think weight/aero penalty may be almost non-existant.
4ibanez
by 4ibanez
Double post
dim
by dim
I've had my first ride today on my new bike (1985 Miyata One Thousand) .... I have fitted the GP5000 clinchers in 32mm wide ... I will update this thread in a few months time with my thoughts
Trek Emonda SL6
Miyata One Thousand
RocketRacing
by RocketRacing
Just got a single gp5000 25c to test on my bike. I have aero rims and planned on a 23/25 combo... assuming a mounted measurement of 24/26mm (17.5id rim).
The 25c measured 25mm at my typical 65psi. Very nice, as that is perfect for my rims (25.5 at brake tracks, up to 28mm mid rim). I will give them time, and a ride or two, and remeasure. On the same rims, the gp4000s2 with a bit of use are 27mm.
Also, They are far easier tires to mount than my gp4000s2’s.
Alumen
by Alumen
I have ordered 2x GP5k clinchers in 23mm and on my scale they weigh respectively 202 and 203 gram.
Out of the box they felt exactly like the GP4k's and were very easy to mount on my Fulcrum 4 wheels. Though they are feeling less supple then my Vittoria Rubino Pro's they are replacing. The Rubino's are 150tpi and the 5k's 110tpi and so the difference is clearly noticable when holding both tyres in your hands.
Tonight I will do a test ride, I have ridden GP4k's in the past as well (both 23mm as well as 25mm), I really wonder how they will hold up in terms of grip and speed.
CAAD 13 Disc
CAAD 10 2015 R.I.P.
28, the real 25
dim
by dim
something that I noticed yesterday with my 32's .....
we had heavy rain and when I stopped cycling , I felt the tyres to check air pressure .... both tyres were very sticky (on the sidewalls aswell as the tread part ....
however, when there is no rain/water on the roads, the tyres feel normal (not sticky)
Trek Emonda SL6
Miyata One Thousand
