One percent over the magic sub-6kg!
Any tips for losing 60g+ without disproportionate expense? Not prepared to compromise on functionality, e.g. tyres, brake pads, saddle etc. Also not wanting to spend 100s swapping the already fairly light stem and bars for ones that are just a little lighter..
I could just cheat and take the computer off I suppose!
Sorry about the uninspiring background, I'll try to take it somewhere nicer soon..
https://flic.kr/p/24cut1r
Not absolutely everything has been weighed individually. Cables etc. are guestimates (as are the ergos) and I can't be bothered right now to take the pedals off! Most stuff has been weighed however.
Frame: Ridley Helium SLX Pure Line (bare except for RD hanger) - 777
Fork: (uncut 305), cut - 278
Headset: (as supplied) with Risk top cap and bolt - 77
Other frame fittings: (as supplied) - 23
Spacers: generic carbon - 9
Bung: Colnago 50mm - 30
Bars: 3t Ernova LTD 40cm (38cm between hoods) - 175
Stem: Ritchey c260, 110mm - 110
Seat Clamp: (as supplied) -15
Seatpost: Darimo T1 - 77
Saddle: Specialized S-Works Romin Evo 143mm - 128
Wheel, front: Campagnolo Bora One 35 tubular - 526
Wheel, rear: Campagnolo Bora One 35 tubular - 680
Tyre, front: Vittoria Corsa G+ tubular 23mm - 268.5
Tyre, rear: Vittoria Corsa G+ tubular 25mm - 280
Cassette: Campagnolo Record 11sp 12/27 - 230
Lockring: Campagnolo Record - 8
Skewers: generic Ti - 43
Ergos: Campagnolo Record 11sp mechanical - 348 (?)
Rear derailleur: Campagnolo Record 11sp mechanical - 175
Front Derailleur: Campagnolo Record 11sp mechanical - 76
Cranks with fittings & pedals: P2M NG Campagnolo, 11sp (52/36), Speedplay with spindles from TiSpindle.com - 961
BB: Campagnolo PF30 cups - 75
Brakes: EE G3 standard mount (pair) - 172
Brake pads: Campagnolo red carbon x4 - 27
Chain: Campagnolo Record (53 links) - 223
Bar tape: Deda padded, with plugs - 30 (?)
Bottle Cages: 2x Carbonworks - 15
Cage bolts - 2.5
Computer: Wahoo ELEMNT Bolt - 61
Computer mount: Wahoo outfront aero - 25
Brake cable housing: Alligator i-link - 25 (?)
Shift cable housing: Campagnolo - 40 (?)
Shift cables: Campagnolo - 30 (?)
Brake cables: Campagnolo - 30 (?)
Barrel adjusters: SRAM - 6 (?)
Total as listed - 6056
https://flic.kr/p/2eJm4Mb
https://flic.kr/p/24curVv
Love the EE brakes incidentally. Best unnecessary extravagance I've ever indulged in!
