do you size and fit your cross/gravel bikes the same as your road bikes?
Catagory6
by Catagory6
do you go for a more upright positioning?
do you go for a different geometry?
spud
by spud
I've got my gravel bike set with the same reach, and 1/2" less drop from my standard aggressive road position. I think I will eventually reduce reach by putting 1 cm shorter stem on, while also raising bar height by about 1 cm. Reason is that while riding gravel roads the position is great, but decending on rough stuff like jeep trails and single track, position puts too much weigh on my hands.
spdntrxi
by spdntrxi
pretty much what spud said... it's the descending on rough stuff that will make you alter the fit. If you dont do any of that you can live with same kind of fit. Nothing like -15% of rain rutted singletrack that will make you wish for Full suspension and a dropper
Catagory6
by Catagory6
spdntrxi wrote:
Fri Feb 15, 2019 5:16 pm
do you live in new england?
i'm so up to my eyeballs with the weather
spdntrxi
by spdntrxi
Catagory6 wrote:
Sat Feb 16, 2019 3:11 am
San Francisco Bay area... it's been mostly rain for a few week now.. snow down to 2500 feet or so.
moyboy
by moyboy
I would go with a more relaxed and upright geometry vs. the aggressive race position. Also probably 2cm wider bars than my road bike for stability in the rough stuff.
Jugi
by Jugi
When getting a CX for winter and mixed riding duties, I selected a frame which was only 5 mm shorter on reach compared to my road bike. After adjusting everything, to my surprise I actually ended up at almost exactly same effective stack & reach numbers (handlebar dimensions etc. included). Although the fit is almost same, it remains quite different to ride because of differences in BB drop and head tube + seat tube angles.
AZR3
by AZR3
My 3T is close to my SuperSix Evo (little higher stack [Large slammed 3T vs 56cm slammed Evo] and about identical reach) but with wider bars (42cm vs 38cm)
Grobar
by Grobar
Hi guys,
I currently ride my roadbike which have 515mm stack and 382mm reach and 11cm slammed stem. My saddle height is ~69cm and I am 90% of the time in the drops with no pain at all. I am 171cm. I am looking to buy a gravel bike and I hesitate between two size: XS 544mm and 365mm /or/ S 563mm and 375mm.
What would you recommend to me ?
spdntrxi
by spdntrxi
50 more stack is alot... I'd probably choose XS between the two. I found less reach is nice especially when bombing down the rough stuff.
onemanpeloton
by onemanpeloton
spdntrxi wrote:
Fri Feb 22, 2019 4:32 pm
I agree!
2017 Giant TCR Disc
2015 Giant TCX
2016 Cube Stereo 140
Grobar
by Grobar
Thanks for the reply, I am also thinking about XS but my LBS is pushing for S as he thinks I need more a upright position for gravel.
TheRich
by TheRich
Do you mean reach as in the frame measurement or the fit measurement, or both?
If you want stability, add wheelbase or move the bars back, or both. (ignoring HTA and fork measurements)
spdntrxi
by spdntrxi
TheRich wrote:
Fri Feb 22, 2019 5:46 pm
lets assume he stays with same stem/bars..reach will be roughly 20 less... my road and gravel has very similar geo's in terms of reach (frame).. I have a 20mm less stem on my gravel bike. When I had 120 stem on my gravel, it took me one downhill single track to say to myself a shorter stem would nice.
Grobar
by Grobar
Yes I will ride exactly the same bars-stem combo on my gravel than on my road bike. Just the bars are aluminium instead of carbon. And I already have a copy of my current stem in 11cm also.
