Titanium bolts for road disc calipers?
kode54
by kode54
Has anyone replaced the standard bots that come with the road calipers? Either post- or flat-mount calipers, the bolts that comes with the calipers have ridges and washers on them. This is so you can install the plastic stop lever on the bolt to prevent it from working it’s way loose.
But if you use blue Loctite on the threads, this should keep it together, right?
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Chebacco + DA9170 + Enve G23 CK CL hubs
- Allied Able + DA9170 + Enve G27 CK CL hubs
TobinHatesYou
by TobinHatesYou
SRAM Red/eTap HRD calipers come with titanium bolts.
kode54
by kode54
All the Shimano caliper bolts seem like specific bolts just for calipers. Flat-mount bolts are also different but all are heavier steel bolts.
TobinHatesYou
by TobinHatesYou
Don't overthink this. You can use steel or titanium, button or socket cap bolts. The important thing is to use the washer to protect the frame/fork around the mount. Some blue Loctite for insurance is fine.
kode54
by kode54
great. thx Tobin.
yes...use washers so the caliper stays put when tightening the bolt down.
