TT cables for campagnolo
ChristianB
by ChristianB
Hi Weenies,
I am rebuilding my TT frame from Shimano to Campagnolo, both mechanical. I can see that campgnolo has a special set of cables for TT shift and brake levers (CG-SL500 & CG-BL500), but can anybody tell me the difference between these and the standard CG-ER600 - and are they necessary. They are quite hard to come by.
Thanks
Christian
audiojan
by audiojan
Always just used the standard Campy shifter/brake cables....
ParisCarbon
by ParisCarbon
If I recall I think the TT specific ones were just longer to accomodate for the extra length of the shifter mounted on the aerobar...
ChristianB
by ChristianB
Thanks,
Thats what I thought as well. I guess I will just measure the length and see if it is ok.
Cheers
joeyb1000
by joeyb1000
Brake cable housing is thinner to accomodate bars with internal routing. I didn't check to see if the length was different.
ChristianB
by ChristianB
Thanks Joeyb1000,
that makes perfect sense.
