ee brakes direct mount front/rear differences?
alcatraz
by alcatraz
Hi wws
My friend with a 2016 rim brake emonda slr frame is looking for brakes.
I've found single ee brakes sold cheaper than the pair.
The question is then, how can I determine if they can be used together? Do ee direct mount brakes come in front/rear or are they universal?
I'm adding pictures of the two brakes I'm thinking about buying.
Additionally, how does the previous version compare to the latest when it comes to:
stopping power
weight
These previous versions are sold at 75% of the price of the latest version. Isn't it worth it?
Thank you!
spdntrxi
by spdntrxi
they can be universal (if they fit) some of the rears are "uglier" which usually get placed on bikes with under BB brakes.
alcatraz
by alcatraz
Thank you very much.
Are direct mount emonda frames universal front/back? It's a rather large frame 58cm so I believe (not sure) the seat tube junction is far enough away for the cable routing.
shimmeD
by shimmeD
Don't know what the situation with the Emonda you're trying to fit but I recall reading Prova's Mark Hester saying that the ee brake is sensitive to cable length esp not being too short. So watch out for that.
Less is more.
alcatraz
by alcatraz
Anyone?
Can someone with emonda and direct mount eebrakes please help confirm a bit?
Thanks
eric01
by eric01
cane creek sells different models for direct mount front/seatstay, direct mount seatstay - short lever, and direct mount chainstay.
The sku for direct mount front/seatstay implies that same model could be used front and rear. The seatstay - short lever model is for bikes with clearance issues, typically smaller frames.
AX Lightness Vial Evo, Carl Strong Titanium
Calnago
by Calnago
Whatever differences there may be between the actual calipers front and rear or current version vs non current version, the emonda frame will not be a hindrance. Where fitting problems more often crop up is with very small frames and/or dropped seat stays.
photek
by photek
I have a 2018 Emonda with latest eebrakes and the front and back calipers are identical.
2019 Trek Emonda SLR, SRAM eTap, eeBrakes, Venn 44 wheelset - 6.4 kg
kode54
by kode54
yes, for mounting under chain stays.
But for Emonda, if on seat stays, you need to use the same as the front caliper.
spdntrxi wrote:
Tue Feb 12, 2019 2:44 am
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
alcatraz
by alcatraz
Thank you very much!
