Rear DT Swiss 240s End Cap
maxwkh
by maxwkh
Does anyone knows if the end cap (thru bolt 135/10mm rear) for DT Swiss 240s Centerlock (classic vs straightpull) are the same?
Parts number HWGXXX0004634S vs HWGXXX0001803S.
Was wondering if they are interchangable since the only differences between them looks like just the metal ring around the edge.
DT website says HWGXXX0001803S is for straightpull while HWGXXX0004634S for the classic hub but most online stores only mentioned HWGXXX0001803S for DT240s (wondering it actually works on both and it is the same?).
So the question is, since there are lot of HWGXXX0001803S out there at a cheaper price, do you think I can get it for my classic DT240s centerlock hub? Thanks!
spdntrxi
by spdntrxi
if they make 2 different sku's.... chances are they are different. Otherwise they could spec the same part for both. End caps are pretty cheap..I'd get the correct one.
maxwkh
by maxwkh
spdntrxi wrote:if they make 2 different sku's.... chances are they are different. Otherwise they could spec the same part for both. End caps are pretty cheap..I'd get the correct one.
Thanks! Bought the right one.
