Madone SLR ... the first 1000km
Johnny Rad
by Johnny Rad
So much left to learn on this beauty... all of you beat me to it, but we share the same questions.
- Frame size?
- H1 or H2?
- Light?
TobinHatesYou
by TobinHatesYou
That’s definitely a 50cm and there’s no H1/H2 split with the new Madone SLR. There’s only H1.5 with -7 and -14 degree stem options.
When I looked at stem options for a 54cm Madone SLR, a -14deg 110mm stem resulted in a 1mm shorter reach, but also a 3-4mm lower stack than a -7deg 110mm stem on a 54cm H1 Emonda. Now if you’re using a -17deg stem on an H1 bike, you’re probably out of luck without sizing down.
RocketRacing
by RocketRacing
Fantastic looking bike, and photos. The clean integration and non all-black look is refreshing. I also think the seatpost light is a slick feature (that i had not noted before).
