sfo423
lazypete
by lazypete on Tue Mar 26, 2019 11:19 pm
I've been using a digital one from Clarke Tools (Clarke Pro, Model # PRO235) for quite a while. It's great, or was until I lost a wee grub screw from the back and doesn't want to work now. On e I find a screw to fit it'll hopefully resume service
parajba
by parajba on Fri Apr 05, 2019 10:30 am
I need a new torque wrench. Any recommendations? I don’t want to throw money away but I don’t mind spending a bit if it will last many many years and if it’s accurate and reliable.
kode54
by kode54 on Fri Apr 05, 2019 2:08 pm
I use the Effetto Mariposa non racheting torque wrench. I like that the head is smaller and allows me to squeeze into tight areas where the racheting version could not. I have both but mainly use the non racheting head more nowadays.
- Factor 02 VAM Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Factor LS Disc + DA9170 + Enve G23 CK CL hubs
- Repurposed Guru Praemio R w 3D disc dropouts + DA9170 + Enve G23 CK CL hubs
parajba
by parajba on Sun Apr 07, 2019 8:05 am
Nefarious86 wrote: ↑Fri Apr 05, 2019 12:40 pm
Giustaforza II pro hands down. Light, comfortable and easy to use. L
Sent from my SM-G975F using Tapatalk
Thanks, is it this one?
https://m.probikekit.co.uk/bicycle-tool ... 72539.html
kode54 wrote: ↑Fri Apr 05, 2019 2:08 pm
Thanks, is it the one that I quoted above? Or is there a better model? Money is not a problem as I would like to buy something that will last me many years and remain accurate, and be easy to use.
parajba
by parajba on Sun Apr 07, 2019 1:08 pm
Thanks, so the Pro and the Deluxe model are in essence identical in terms of reliability and accuracy but the Procomes with the ratcheting head whereas the Deluxe doesn’t, but the Pro costs an extra £50?
JKolmo
kode54
by kode54 on Mon Apr 08, 2019 12:10 am
The racheting head is much larger and is harder to get into tight spaces, especially when there are wires or brake cables in the way. You can also use a long reach hex allen socket which comes with both models, but I find that the non racheting head suits me better. i use the Park hex wrenches to get the bolt snug, then use the torque wrench to get it to spec.
parajba wrote: ↑Sun Apr 07, 2019 1:08 pm
pedale
by pedale on Mon Apr 08, 2019 8:41 pm
parajba wrote:Thanks, so the Pro and the Deluxe model are in essence identical in terms of reliability and accuracy but the Procomes with the ratcheting head whereas the Deluxe doesn’t, but the Pro costs an extra £50?
https://www.bikeradar.com/road/gear/art ... est-46517/
On this test, the non-ratcheting head was less accurate. The tester agreed that it might be a misfortune but still good to keep in mind
parajba
by parajba on Tue Apr 09, 2019 5:27 pm
Do you know why the Giustaforza II is not as accurate as the Giustaforza II Pro?
The £50 X Tools Pro from Wiggle seems a good deal.
Some commented that for these prices (£150) you can get a real professional tool (Britool AVT100A, for example).
I think I will get the Lifeline for £50. And replace it every 4-5 years. The Giustaforza needs to be sent to the manufacturer every 5000 clicks for calibration.
parajba
by parajba on Thu Apr 25, 2019 3:36 pm
@Nefarious86:
Just bought the Giustaforza II Pro.
Do I need to do anything the first time I use it, or before each use, to ensure accuracy? There is a leaflet inside with ‘Testing instructions’. What do I need to test it for?
parajba on Fri Apr 26, 2019 10:52 pm, edited 2 times in total.
