11 speed wide cassette that are light.
bm0p700f
by bm0p700f
Don't use Ali or to cassettes off road they will be ground away. They are for nice days.
ryanw
by ryanw
SRAM Force (PG1170) 11-36 comes in at 368g.
I had a 10-42 on previously but the jumps were too much.
Allez Sprint Disc - 7.60kg
SL7 S-Works - 6.73kg
www.rhinosworkshop.co.uk
IG: RhinosWorkshop
Marin
by Marin
moyboy
by moyboy
1199 sram is a beauty at 268 grams.
That being said, the new 12 speed cassettes might be good ones to consider.
anykarthik
by anykarthik
Frisco wrote:
Wed Jan 23, 2019 9:17 pm
You should be able to fit at least a 11-42 without a wolf tooth using the RX805 derailleur. At least it worked for me and there was some margin left on the adjustment screw.
Are you running a 1x or 2x front crank? Because beyond the b-screw, the pulley arm has to also be long enough to handle the jump from big-big to small-small in a 2x setup.
I've got the Ultegra RX with 48/32 up front. I was planning on 11-36, but if 11-40 works, then I'd vastly prefer that
Attermann
by Attermann
Does anyone know if there exists an 10-30? Or something like that
Marin
by Marin
Attermann wrote:
Sat Feb 02, 2019 7:49 am
3T Bailout 9-32, I have one.
markdjr
by markdjr
anykarthik wrote:
Fri Feb 01, 2019 6:23 pm
I was able to run 50/34 11-40 with the RX derailleur. Big/Big doesn't result in catastrophic failure but is certainly not recommended.
spdntrxi
by spdntrxi
Since I have 2 650B wheelsets currently, I have 2 cassettes coming
1. XTR 11-40
2. Sram XG-1199 10-44(wolftooth 44 instead of 42)
gonna have a pretty low gear if I stay with 2x...probably walk faster
MichaelB
by MichaelB
Are there any other XD driver options that are affordable around the 11-36 ratios ??
Also, currently run 50/34 & 11-34 cassette with Rx800 RD. Big-big is OK, but small-small is slightly loose.
How do those that do 50/34 & 11-40 manage it with the same RD ??
spdntrxi
by spdntrxi
^ yeah dont know... my chain is long on purpose right now because I knew I was getting 11-40 or more.
I'm running 48/32 with an 11-34 and small/small is way to loose. I cant use the the smallest 3 as is currently. Hopefully I wont need to do a much to run the 40t...not sure about 44 though. I have a goatlink and chain links ready.
pdlpsher1
by pdlpsher1
MichaelB wrote:Are there any other XD driver options that are affordable around the 11-36 ratios ??
I’m running 50/34 and 11-40. Proper chain length (full length DA chain in my case) and proper B screw adjustment.
MichaelB
by MichaelB
@ pdlpsher1 - can you provides pics at each extreme as I reckon my setup is also done ‘properly’ , but any additional insight will be appreciated
Edit : Shimano specs being conservative show total capacity of the RX800 is 39T (e.g. same as my setup) , but the setup from pdlpsher1 is 45T total, and that’s waaaay over, so keen to see what the secret sauce is :P
fourfa
by fourfa
I'm running 46/30 in front, and one pair of wheels with 11-36, the other with 11-32 ,with 113 links in the chain. Also with RX800. If I trim the B-screw for the 11-36, everything works great, still some tension in small-small, not too stretched in big-big. If I trim the B-screw for the 11-32, it's too loose in small-small. The 32 cassette shifts great trimmed for the 36, so I don't care. So try adding a little tension and see if it's acceptable?
MichaelB
by MichaelB
fourfa wrote:
Fri Mar 01, 2019 6:16 am
......If I trim the B-screw .....So try adding a little tension and see if it's acceptable?
Cheers, will give it a go
