11 speed wide cassette that are light.
Frisco
by Frisco
You should be able to fit at least a 11-42 without a wolf tooth using the RX805 derailleur. At least it worked for me and there was some margin left on the adjustment screw.
spdntrxi
by spdntrxi
Frisco wrote:
Wed Jan 23, 2019 9:17 pm
damn.. I've heard of 40.. 42 wow
Frisco
by Frisco
It was recommended by a local and he actually went from a 40 to 44 recently. Having the big cog is nice when you want it. I still find myself wanting more. Ethirteen has a 303g 9-46T that might be worth looking at if you decide to try going big. I’m not sure if 46T would fit or if you’d bottom out the limit screw though.
spdntrxi
by spdntrxi
how many links in the chain.. I have no experience with such large cassette.. is 116 links enough generally for 40t.. remember am I 2x upfront with a 48t
Frisco
by Frisco
I have 46/30 with the 11-42T and a KMCX11SL - I just checked and have 6 links left. So 42 should work but anything else would be an experiment.
spdntrxi
by spdntrxi
30/42 wow... that would definately help ...
LeDuke
by LeDuke
I'm running a Force 1 set up with a 10-42 XX1 cassette on my...gasp...road bike. 48t NW ring.
Works very well. Sure, the jumps in gearing aren't ideal for some, but it doesn't bother me at all.
spdntrxi
by spdntrxi
LeDuke wrote:
Thu Jan 24, 2019 4:50 pm
you think XX1 cassette will play well with Shimano ?..
LeDuke
by LeDuke
Plenty of people running XTR shifter + RD with an XX1 cassette.
You can also run a Di2 XTR RD with DA shifters.
spdntrxi
by spdntrxi
^ thanks.. 42 is more then enough... maybe even 40. Love the lack of weight on the XX1 cassette.. Really prefer to stick with my 805 Di2 RD... it's been good.
Frisco
by Frisco
do that XX1 42
spdntrxi
by spdntrxi
Frisco wrote:
Sun Jan 27, 2019 12:30 am
do that XX1 42
XX1 most expensive but lightest solution... :)
XTR 11-40 would be a wash in weight compared to my 11-34
I have to stare are those ratios a little longer buy an XD driver for my hub.. really hope a dont need a wolftooth link of anykind.
markdjr
by markdjr
I was able to run the XTR 11-45 with my di2 rx derailleur no wolftooth. I am currently running a Garbaruk @298g 11-46 and had to add the Wolftooth. I have experimented with a bunch of setups, pretty happy with my 50/34 11-46, marginal weight penalty for the gear range.
ooo
by ooo
Do you mean 10-45/11-40 XTR or 11-46 XT?
markdjr
by markdjr
ooo wrote:
Wed Jan 30, 2019 8:55 pm
I forgot it was a shimano with the wolftooth 45 tooth cog. It was pretty heavy which is why I moved to the Garbaruk cassette.
