Reynolds RZR lateral play in rear hub
Hello
I've got few lateral play on my Reynolds RZR rear hub.
Do you know how can we disasembly the hub? Or must I send the wheel to Reynolds? Or does someone in Europe do the maintenance of the hub?
And on left side of the hub, the small part (in red in photo) can move left to right. It is not fixed to the axle Let me know Please
Quote from road.cc
"The deep-flanged hubs come with carbon bodies and house super-smooth bearings. You're not allowed to open them up for maintenance, though. If you do you'll invalidate the two year warranty. They have to go to an authorized Reynolds dealer for servicing."
Are you still under warranty?
If out of warranty I think reynolds should still help with some instructions.
I'm not familiar with reynolds hubs. I'd try find some info on how the hub works. Reynolds should be able to inform you if you're out of warranty. Maybe we can help interpret if you post their answer here.
/a
/a
try using soft jaws in a vise and see if they pop off. most likely with all hubs, the end caps are separate from the axle itself...like DT Swiss and Chris King (my experience). from there, you could probably determine how they put them together.
- Factor 02 VAM Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Factor LS Disc + DA9170 + Enve G23 CK CL hubs
- Repurposed Guru Praemio R w 3D disc dropouts + DA9170 + Enve G23 CK CL hubs
If the hub end caps don't have some way to hold them either with a cone wrench or an allen key in the hole, they are 99% likely just for pulling off.
You need a tool that can grip the cap without scratching or deforming it. Then pull it straight off.
After that the freehub should come off by pulling straight. Check afterwards the axle for play. Explain what you see and feel.
A normal sealed bearing hub has 4 bearings. Two in the hub and two in the freehub. Play issues are easier found with the freehub off.
If you habe a preload mechanism you'll find a nut of some sort on the axle that can compress or decompress the bearings.
Play can either be explained by a shifted or damaged bearing, worn axle, bad tolerances, cracks, or a misadjusted preload.
Sometimes it's just a loose skewer and some friction in the hub preventing the parts to compress properly.
The hubs on an RZR are Tune I believe, so you can try to find someone in Europe who's familiar with Tube hubs. Hope that helps.tfayet wrote:Hello
Hello
Finaly, it is really easy to remove ends caps, an old quick release, and I remove the ends caps knocking with a hammer on the quick release.
Inside, from right to left we find:
- right end caps
- freehub with 2 6802 bearings (24/15/5)
- 2 shims 20.5*15*0.4
- 2 * 6802 bearings inside the midle of the hub
- one 6802 bearing
- one shim (24*15*1) to protect left bearing
- one shim 20.5*15*0.4
- lets end caps
I'm gooing to buy some shims 20.5*15*0.4 and less thick to try to remove lateral play. If still present, I'll change bearings.
I'll post some photos later or the hubs and parts removed
Thanks again for your helps
- right end caps
- one 6802 bearing
- lets end caps
Check what type of play you have before buying stuff. Adding a shim does nothing in some cases.
Are the hub bearings pressed fully?
Inspect the axle for wear at the bearing locations.
Is the play in the bearings or in the bearing/axle/hub interface?
Is it lateral or radial play?
Are the bearings gritty?
If the play is in the bearings replace them with low play bearings like SKF. Forget ceramic. At 6802 size you will crush those balls into dust.
Because the bearing races are so small it's possible you've worn the axle or produced a gap between bearing and hub shell. You will need to use retaining compound to fix the bearing.
I have a hub with 4x6802 bearings too and the weakest link is that inner wheel bearing. It carries almost all the weight and will wear fast. This bearing needs to be high quality steel to eliminate most of the play. Steel bearings of different brands have different tolerances. I had to test several brands before I realised that skf were the best for me. Low play and low cost, roll very nicely. Together with retaining compound they brought my old hubs back to life.
Ok, Thanksalcatraz wrote: ↑Mon Jan 21, 2019 7:53 amCheck what type of play you have before buying stuff. Adding a shim does nothing in some cases.
It is only lateral play. But 'll change also bearing you are right
I Will take https://www.123roulement.com/roulement-6802-2RS-SKF.php
In the hubs, bearing are directly in contact with carbon. Do you think I can use retaining compound without dalmaging hub and carbon.
And f I need to change bearing after, how to remove bearing
There are different strength retaining compounds and for different size gaps. They aren't permanent locking compounds, they just help to fill the gaps. Heat can be applied to losen them a little, unless you use the wrong kind that is like 150C proof.
If your play is in the interface then try a small amount first. A drop smeared very thin on the outer race is enough to make a world of difference.
You need to use it sparingly so that it doesn't go into the bearing and ruin a new bearing.
I don't think it will damage the carbon. Some pros would say you need to use a special primer first but I've used without with no problem.
My memory isn't great but Loctite 641 is a gentle compound for small gaps, then you can go to 609 which is thin but high strength (careful), and if you have big play you can try 638.
638 might be better than 609, but best to double check first.
