2018 Tarmac S works SL6 - Dura Ace 9100 Cranks Compatibility
juang1985
by juang1985
Hello Everyone
First time posting long time follower.
I am a total noob when it comes to bottom brackets.( now that I got that out of the way)
I am about to complete the parts list for my new build a SL6 Sworks tarmac, I decided to go with the Dura ace Di2 9150 groupset.
the dura ace 9100 crankset is 24mm diameter spindle, I want to know the best way to make it work with my frame I think is BB30 (could be wrong)
Anyone out there knows the compatibility of the Tarmac SL6 and the Dura Ace 9100 Cranks?
I attached a picture of the bottom bracket area of my Frameset any help of the parts that I will need would be greatly appriciated.
Thanks!
spdntrxi
by spdntrxi
your BB is already there... cant tell the size obviously, but you can get some calipers and measure. The diameter does not look particular large to my eyes... it might be 24 already. Do you know what crank was in there before ?
juang1985
by juang1985
spdntrxi wrote:
Wed Jan 16, 2019 6:03 am
Thanks for your reply, I tried to inert the crankset in there and there is lots of play it has to be 30mm vs 24mm dura ace crank
I dont know what crankset was there, I would assume the Sworks crankset possibly.
spdntrxi
by spdntrxi
juang1985 wrote:
Wed Jan 16, 2019 6:15 am
lots of play then it was probably was a 30mm sworks crank.. too bad you have a nice ceramicspeed BB in there already.
juang1985
by juang1985
spdntrxi wrote:
Wed Jan 16, 2019 6:19 am
Yes this gotta be 30mm and the Cranks are 24mm.
so would this fix my issue?
I am just a bit lost, not sure what bottom bracket to buy
https://www.amazon.com/CeramicSpeed-BB3 ... ref=sr_1_2
cyclespeed
by cyclespeed
I wish people would stop calling it a 'BB'. It´s not, it's just 2 bearings inserted into the frame.
The standard set up for an SL5 or SL6 Tarmac is 2 bearings pressed into the frame. With internal diameter of 30mm.
The Sworks crankset just slips straight in with a bearing shield either side and an adjustable spacer.
To fit a 24mm axle like the Dura Ace you need an adaptor that slides into the current bearing and reduces it to 24mm.
L3X
by L3X
Cyclespeed is right, by default this frame comes with CeramicSpeed bearings for OSBB.
VTR1000SP2
by VTR1000SP2
Take it to a shop, have them order and install the correct part for your configuration.
cyclespeed
by cyclespeed
VTR1000SP2 wrote:
Wed Jan 16, 2019 12:13 pm
Good luck with that, my LBS didn´t have a clue and gave me a ROTOR Aldhu with an axle that was way too long.
They then got me a SRAM Red and installed it wrong.
Better to sort these things out yourself IME.
VTR1000SP2
by VTR1000SP2
I’m sure there are competent mechanics out there. Just gotta find them.
liam7020
by liam7020
L3X wrote:
Wed Jan 16, 2019 11:14 am
cyclespeed wrote:
Wed Jan 16, 2019 9:32 am
No offence but you're wrong, it's a bottom bracket - OSBB=OverSizedBottomBracket. OSBB is Specialized's version of BB30. Would someone care to hazard a guess what the BB stands for in BB30? On the Ceramic Speed website the OSBB bearings are listed under the section marked bottom bracket and whilst it may not be the fondly remembered BSA threaded bottom bracket, a bottom bracket it is nonetheless. Would someone care to put a name to that area of the frame where the OSBB/BB30/PF30/BB86/BSA/386EVO/PF41 all press/insert/thread into? Let me see now - oh yes that would be the bottom bracket!!!
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
juang1985
by juang1985
Thank you all for your replies.
Would the adapters work well or would something like this be better?
https://praxiscycles.com/product/shimano-conversion-bb/
Or this
https://www.endurobearingsonline.com/products/bb30-24
So many options want to install the best possible option
cyclespeed
by cyclespeed
liam7020 wrote:
Wed Jan 16, 2019 12:38 pm
They can call it what they like, but it doesn´t change the fact that it´s just 2 bearings. I wouldn´t call that a BB personally.
For me, a BB is a piece that contains cups, sleeves, bearings and threaded inserts. You can´t 'buy' a Specialized BB, you can just buy the bearings……
liam7020
by liam7020
And yet when I took delivery of my SL6 the CeramicSpeed box containing the bearings etc was clearly marked "bottom bracket".
juang1985
by juang1985
Guys,
Bottom bracket or bearings just let it be. I agree with both of you, it does not look like a bottom bracket it looks like a pair of bearings but They do call it a bottom bracket.
Have any if you heard or tried any of these two?
Or this
I want the best permanent option for this build, please advice
