5,474 Supersix Black Inc 2013
Darmen
by Darmen
Hi weightweenies
Hereis the build list for my 5,474 Supersix Black Inc 2013
Actual Weight
NiFTY
by NiFTY
Pictures. Hows the front shifting w da? Any rubbing( as you can't trim)
Darmen
by Darmen
Hereis the parts weight
the handle bar is little bit like aeronova handle bar, and nice suspension size 400 90
this titanium qr is light and so handy, but i think i need to replace it with lighter qr
standard headset with 1 cm dust cap, try to reduce 20g, FSA SL headset is on the way :D hopefully save 20g
standard fork cut until no spacer
Frame size 52 include PF30 Bottom Bracket
Extralite expander + absolute black top cap, save about 6g of the original si, extralite expander is little bit hard to install, i had to move rubber seal into the middle of expander and it works.
Dura ace 9000 FD with farnear bolt
XG1190 cassette 11-28, i had to remove the seal to save about 6g
hereis trickiest part. i really want to use PF30 BB couple it with my Easton crank which original have 129mm spindle. to make it works i had to bought 104mm spinde and make some spacer using carbon steerer spacer.
i cut the seatpost to my size + 10cm minimum insert
Darmen
by Darmen
NiFTY wrote:
Mon Jan 14, 2019 5:00 am
Hi its updated, yes its rubb a lot if cross chainring :)
Darmen
by Darmen
KMC X11SL
Born as Look Keo Blade 2 with Cr shaft. got upgraded to Ti shaft.
Standard Seatclamp from cannondale, weight 16g
KCNC CB3 + Corima Brake Pads 168g. its lighter than ee brake
custom wheelset G3 pattern straightpull R36 rim 50mm total weight 1365 (excl qr)
Barfly Mini. Garmin & Gopro in harmony. but weight ore than i expected
Skully light
Darmen
by Darmen
allhill
by allhill
nice bike!
where you get your wheelset? 50mm profile with below 1.5kg is awesome.
nickf
by nickf
Nice build.
Seatpost clamp you can save a little. Worked great on my 2015 Evo hm. 9g.
https://rover.ebay.com/rover/0/0/0?mpre ... 0957470489
prebsy
by prebsy
Feels like it would be worth the weight penalty to have the yaw FD. You could definitely save a bunch on the skewers some Ti bolt ons from eBay are my go to. Super clean , cheap and < 30g
Sent from my Pixel XL using Tapatalk
Strava
Current Stable:
Specialized Allez Sprint Disc
Cervelo Aspero
Scott Spark 910 Contessa
Darmen
by Darmen
allhill wrote:
Wed Jan 16, 2019 10:48 am
nice bike!
I bought it on aliexpress it cost less than $500 (excl tax) about 2 years ago. it has 20.5mm width and fit perfect with my 20mm tires.
But now they even sell lighter wheels, weight less than 1.1kg for 50mm profile :shock:
Darmen
by Darmen
nickf wrote:
Wed Jan 16, 2019 1:35 pm
Nice build.
Nice. i've been planning to buy lighter clamp. but still cant decide whether darimo sub4 or yuniper 6g. Altough, still doubt the performance
Darmen
by Darmen
prebsy wrote:
Wed Jan 16, 2019 2:50 pm
The main reason i use DA front derailleur is due to my oval chainring. based on some forums Red FD doesnt shift well with oval chainring, they tend to over shift cause chain drop to the crank.
until now DA front derailleur shift well with my oval chainring, just rub issues if i use cross chainring configuration.
but if changing bolt can save Red FD by 30g, i tempted to using Red FD :twisted:
Darmen
by Darmen
The original headset dust cap spacer weight 15g for 15mm height, then i remember i have a spare 10 mm dust cap weight 10g and a 10mm carbon spacer weight 3g. Saving 2 gram sounds good. when i install the spare dust cap there is a gap to frame, i have to sand the dust cap until no gap and reduce carbon spacer height to 5mm. it turn out the dust cap and carbon spacer now only weight 9g.
ive purchase rockbross garmin mount, weight half barfly, only 22g but i doubt its rigidity
Update weight list
Frame Supersix Black Inc 2013 (705g)
Fork Supersix Black Inc 2013 (282g)
Topcap AbsoluteBlack + Expander Extralite ultrastar 3 (10g)
Headset Supersix (49g)
Headset spacer and dust cap (9g)
Integrated Dropbar RXL (320g)
Bartape Lizard Skin 1.8mm (50g)
Shifter Sram Red (300g)
Front Deraileur Dura Ace 9000 Farnear bolt (60g)
Rear Deraileur Sram Red 22 Carbon Pulley and Inner Cage (130g)
Bottom Bracket Sram Ceramic PF30 (82g)
Spacer + Seal (6g)
Cranks Easton EC 90 (402g)
Chainring Carbon Ti X cam 50T (80g)
Chainring Carbon Ti X cam 36T (31g)
Chainring Bolt Easton EC 90 (5g)
Cassette Sram RED 22 11-28 rubber less (159g)
Chain KMC SL (221g)
Brake KCNC CB3 with Corima pads (168g)
Seatpost NV 22cm (104g)
Seat Clamp Cannondale 30.00mm (16g)
Saddle Astute skylite VT (173g)
Alligator iLink Shifter and Brake (85g)
Front Wheelset Powerway 36 50mm 18 H (615g)
Rear Wheelset Powerway 36 50mm 21 H (745g)
Front Tire Tufo Elite Jet (160g)
Rear Tire Tufo Elite Jet (160g)
Air and Glue (9g)
QR Titanium (49g)
Pedal Look Keo Blade 2 Ti (192g)
Electronic Garmin Sensor (27g)
Garmin Mounting Rock Bros (22g)
Light Skully (14g)
Total 5440g
Klaster_1
by Klaster_1
Darmen wrote:
Mon Jan 14, 2019 5:39 am
IMG-1789.JPG XG1190 cassette 11-28, i had to remove the seal to save about 6g
How's shifting without rubber bands? Was loudness the only thing affected?
rexyi1990
by rexyi1990
NICE BUILD
