Colnago SR9 Stem
scb
by scb
ymisyd wrote:
Wed Jan 16, 2019 1:05 pm
maxice wrote:
Wed Jan 16, 2019 12:11 pm
Whats the difference between the SR9 and the R41 stem? Just been informed my C64 is almost ready, I've ordered the R41 stem but have read somewhere that there were issues with the internal routing on them?
I ordered and thought I was getting the R41, but even the dealer was surprised that the SR9 came instead. The R41 isn't compatible with internal routing.
Same here
maxice
by maxice
I'm planning on running a mechanical setup on this so those bends are worrying!?
ms6073
by ms6073
Wowza, almost US $6500 simply for the disc frameset! :noidea:
What about the Di2 junction A? Is this using the bar end junction or is there a removable plate for installing in the down tube? From the online images, appears to be a downtube installation.
scb
by scb
maxice wrote:
Wed Jan 16, 2019 2:17 pm
I'm doing same thing with SR-12 speed mechanical and have been told it's not an issue.
ymisyd
by ymisyd
Give it a try but there's no way I would do a sharp 114 degree bend with mechanical cables. I'm sure the stem is designed only for hydraulic lines, which can cope with the tighter bend.
ymisyd
by ymisyd
ms6073 wrote:Wowza, almost US $6500 simply for the disc frameset! :noidea:
I'm using the bar end junction. Personally, there's no way I could have that external junction box stuck on the stem. It's what helped me settle on DA rather than Campagnolo.
maxice
by maxice
Imagine the other integrated options on other makes would have similar issues with the bends?
Calnago
by Calnago
Yes, any significant bends in a mechanical cable routing create added friction and compromise shifting. A guy wanted me to build his Madone (last years model). Campy mechanical 12sp was out and I said, well... the only way I want to touch that thing is if we go with Campy 12sp, so I could get some experience with it. So he brings over the frame and we throw out all the parts on the floor. I study it all, especially how the cable routing would have to go and just told him flat out... ya know... I just can’t in good conscience recommend doing a mechanical drive train on this bike. So as much as I would have liked to install the new 12sp mechanical, he went with Di2 instead. With some internally routed bikes, the difference in cable bends etc can be no more than with externally routed bikes, so it’s fine. But when you have to internally route through tight bends in bars, stems. headtube, downtube... compromised shifting is all but inevitable. Will it work?... maybe. Will it work as well as it could without all those bends?... not a chance.
AJS914
by AJS914
I've had that issue with Campy 11 speed just going though bars with internal routing holes.
I see mechanical Ultegra and Dura Ace all the time on the Madone 9. Do people have shifting problems due to cable bends? Is Campy more susceptible to tight bends?
Dansanmartin
by Dansanmartin
Hello ymisyd,
Was the SR9 stem and weird shaped spacers included in the frame purchase or did you have to pay extra for it?
ymisyd
by ymisyd
Dansanmartin wrote:
Sun Jul 28, 2019 9:51 am
Hello ymisyd,
Stem is a standalone purchase - not included with frameset.
frommel
by frommel
The stem came with my 2019 C64 Disc frame.
