long shot.. anyone own a Garmin mount for a Syncros stem?
maddog 2
by maddog 2
Either the Foil or RR stem.
This is the Foil one:
https://www.syncros.com/global/en/produ ... uter-mount
I'm thinking of fitting one to a diffferent stem and need to know the gap between the bolt holes.
Syncros website doesn't say, and I don't really want to order one just to find out.
maddog 2
by maddog 2
or you have a Foil or RR stem and can measure the centre-to-centre gap between the lower two stem clamp bolts?
jfranci3
by jfranci3
I have that exact one. There are better options though. The problem (for me) is that it won't hold a Wahoo Bolt without an adapter and the bolt (and probably the 520) either sits too far away or leaves the front of the mount exposed. I think I have it in my garage with a few drill holes in it, as I tried some things. You can have it for the for the cost of the shipping.
Try this instead - http://edge-mount.bike/?product_cat=specialized
Or take a look at the Bontrager or 3form mounts. The bont is a hassle to get your computer in just the right spot. The 3form is a hassle to get the supports level.
RedbullFiXX
by RedbullFiXX
I run this one from ebay
Fits a range of stems
https://www.ebay.com/itm/Alloy-Bike-Ste ... :rk:2:pf:0
jfranci3
by jfranci3
I have 26mm c to c on the bolt spacing
https://photos.app.goo.gl/mHzpPcaM9x1Now9o7
maddog 2
by maddog 2
brilliant, thanks Jon.
With my current stem I need 21/22mm
